Hi, I’d like to add a disk raw partition to a LXD container.
I’d like to access it like /dev/sda2 inside the container.
I’m using zfs for LXD storage backend.
Could you tell me how to do that?
Thanks!
i would try it with a unix-block device:
https://lxd.readthedocs.io/en/latest/containers/#type-unix-block
Something like:
lxc config device add <container> <name_in_container> unix-block source=/dev/zvol/$yourzfs
Just do some experiments. Your favourite search engine will also give you some hints.
I connected a USB stick on my computer. I used gnome-disks to unmount it from the host, but still not disconnect it (not power down). The device is /dev/sdb1.
$ lxc launch ubuntu:18.04 rawdisk
Creating rawdisk
Starting rawdisk
$ lxc config device add rawdisk myrawdisk unix-block source=/dev/sdb1
Device myrawdisk added to rawdisk
In the container, I run
$ sudo fdisk /dev/sdb1
Welcome to fdisk (util-linux 2.31.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): p
Disk /dev/sdb1: 3.9 GiB, 4126146560 bytes, 8058880 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Command (m for help): q
You have full access to the raw block device in the container.
If you want to mount it, see Unix-block device mounting
If you still want to mount it, you can look for some FUSE package that supports your filesystem.
Thanks for your comments.
simos’ answer works as expected. However I’d like to use disk space from zfs pool.
I did some experiment and found I cannot use zfs dataset as source for lxc config device add unix-block.
As a workaround, I create a file for raw partition in a zfs dataset /tank1/storage1
$ sudo dd if=/dev/zero of=/tank1/storage1/disk1.img bs=8M count=100
Then I mount it as a loopback device.
$ sudo losetup $(sudo losetup -f) /tank1/storage1/disk1.img
$ losetup -a
...(snip)...
/dev/loop3: []: (/tank1/storage1/disk1.img)
Finally I can add this device to a container as a unix-block
$ lxc config device add bionic storage1 unix-block source=/dev/loop3 path=/dev/sdb
In the container, I can see the device.
root@bionic:~# df -h /dev/sdb
tank1/snap/var 382G 1.4G 380G 1% /dev/sdb
The size in the output is not correct, but I can see the correct size with fdisk.
root@bionic:~# fdisk /dev/sdb
Device does not contain a recognized partition table.
Created a new DOS disklabel with disk identifier 0x24f32ec9.
Disk /dev/sdb: 800 MiB, 838860800 bytes, 1638400 sectors
Disklabel type: dos
Disk identifier: 0x24f32ec9
i suggest you to create a real raw image file with qemu-img and use this. That will most probably solve your issue.
If ever possible you should just create a zfs vol/dataset and use this directly.
Going from blockdevice -> mount filesystem -> create raw file -> mount raw file as blockdevice
can be a way, but you loose flexibility and just add complexity without real gain ( imho ) if you leave your zfs ecosystem like this.
Hi, sorry to bring this up again, when we add a unix-block and refer to /dev/sdb1, does LXD maps it to UUID or just de sdX?
Just that I have had situations where you have to pull the drive or a faulty cable, then the OS map it to a different sdX, in this case might break the device added to the container.
Here are the docs for the unix-block device:
It uses the source and path settings. So if you want to refer to a device by UUID you should use the /dev/disk/by-uuid/ paths.
I think it might be working but I keep getting and issue of permission denied on mount.
path: /dev/sdb
source: /dev/disk/by-uuid/*******************
type: unix-block
already added
raw.lxc: lxc.cgroup.devices.allow = b 8:* rwm
But it did not work, any suggestions?
Thanks.
You won’t be able to mount the device inside the container without using syscall interception.
See
