Error: Failed to create storage pool ‘local’: Failed to create the ZFS pool: cannot create ‘disksdb3/proxmox_lxd_prod’: invalid character ‘/’ in pool name
did you come up with the preseed YAML snippet you pasted by your own? Or did you copied it from the output of “lxd init” ran in interactive mode, which since 3.0.0 will offer you to print the preseed YAML which matches your interactive answers?
In the latter case, you probably got a broken YAML, since I discovered that there’s a bug in “lxd init” when run interactively for joining a cluster and the joining node has an existing zfs dataset. The fix for the bug will be released soon, but you should be able to solve the issue by tweaking your pressed and eliminating the “volatile.initial_source” and “zfs.pool_name” keys from the storage pool config. For example:
storage_pools:
source: disksdb3
driver: zfs
Also, I think you should make sure that the dataset is unmounted before running lxd init (I see you have it mounted under /disksdb3).
Regarding using “/” in pool names, that’s apparently not supported by zfs, e.g.:
root@lxd-4fa8fddc-8dd8-4453-9777-41d607698c6e:/home/ubuntu# zpool create disksdb3/proxmox_lxd_prod /dev/vdc
use ‘zfs create’ to create a dataset
I’m not sure what you’re trying to do there and why you want slashes in the dataset name.
I see the dataset as slicing up the zpool, so I was trying use an existing
dataset which has a slash in it as the root of the storage for the LXD
cluster. This is because I don’t want LXD to hog the whole Zpool and I can
use it for backups etc.
e.g.
zpool create disksdb3 /dev/sdb3
zfs create disksdb3/mylxdclusterdataset
so I was giving the dataset above with slash to LXD to use.
I am a ZFS newby so I might be talking rubbish. I’m a Network engineer by
trade
Okay if I understand correctly what you want to do, here follow the steps to create two nodes with a ZFS storage pool linked to a pre-existing disksdb3/mylxdclusterdataset dataset.
Bootstrap node:
root@lxd-fc4943a2-98e9-46cd-8ef8-6b58991a4101:/home/ubuntu# zpool create disksdb3 /dev/vdc
root@lxd-fc4943a2-98e9-46cd-8ef8-6b58991a4101:/home/ubuntu# zfs create disksdb3/mylxdclusterdataset
root@lxd-fc4943a2-98e9-46cd-8ef8-6b58991a4101:/home/ubuntu# lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: yes
What name should be used to identify this node in the cluster? [default=lxd-fc4943a2-98e9-46cd-8ef8-6b58991a4101]: node1
What IP address or DNS name should be used to reach this node? [default=10.55.60.34]:
Are you joining an existing cluster? (yes/no) [default=no]:
Setup password authentication on the cluster? (yes/no) [default=yes]:
Trust password for new clients:
Again:
Do you want to configure a new local storage pool (yes/no) [default=yes]?
Name of the storage backend to use (btrfs, dir, lvm, zfs) [default=zfs]:
Create a new ZFS pool (yes/no) [default=yes]? no
Name of the existing ZFS pool or dataset: disksdb3/mylxdclusterdataset
Do you want to configure a new remote storage pool (yes/no) [default=no]?
Would you like to connect to a MAAS server (yes/no) [default=no]?
Would you like to create a new network bridge (yes/no) [default=yes]?
What should the new bridge be called [default=lxdbr0]?
What IPv4 address should be used (CIDR subnet notation, auto or none) [default=auto]?
What IPv6 address should be used (CIDR subnet notation, auto or none) [default=auto]?
Would you like stale cached images to be updated automatically (yes/no) [default=yes]?
Would you like a YAML "lxd init" preseed to be printed [default=no]? yes
core.https_address: 10.55.60.34:8443
core.trust_password: foo
cluster:
server_name: node1
enabled: true
cluster_address: ""
cluster_certificate: ""
cluster_password: ""
networks:
- config:
ipv4.address: auto
ipv6.address: auto
managed: false
type: ""
storage_pools:
- config:
source: disksdb3/mylxdclusterdataset
driver: zfs
- config: {}
nictype: bridged
parent: lxdbr0
pool: local
Joining node:
root@lxd-4fa8fddc-8dd8-4453-9777-41d607698c6e:/home/ubuntu# zpool create disksdb3 /dev/vdc
root@lxd-4fa8fddc-8dd8-4453-9777-41d607698c6e:/home/ubuntu# zfs create disksdb3/mylxdclusterdataset
root@lxd-4fa8fddc-8dd8-4453-9777-41d607698c6e:/home/ubuntu# lxd init
What name should be used to identify this node in the cluster? [default=lxd-4fa8fddc-8dd8-4453-9777-41d607698c6e]: node2
What IP address or DNS name should be used to reach this node? [default=10.55.60.66]:
Are you joining an existing cluster? (yes/no) [default=no]: yes
IP address or FQDN of an existing cluster node: 10.55.60.34
Cluster certificate fingerprint: 4668b46fd423d483b462084d1bf2cd49eff4d747cfde3895151cd8c904935292
ok? (yes/no) [default=no]: yes
Cluster trust password:
All existing data is lost when joining a cluster, continue? (yes/no) [default=no] yes
Choose the local disk or dataset for storage pool "local" (empty for loop disk): disksdb3/mylxdclusterdataset
core.https_address: 10.55.60.66:8443
cluster:
server_name: node2
enabled: true
cluster_address: 10.55.60.34:8443
cluster_certificate: |
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
cluster_password: foo
networks:
- config:
ipv4.address: 10.238.99.1/24
ipv4.nat: "true"
ipv6.address: fd42:43c0:d098:602f::1/64
ipv6.nat: "true"
managed: true
type: bridge
storage_pools:
- config:
driver: zfs
- config: {}
devices: {}
Please note that this assumes you’re using a build of LXD containing this fix:
If you can’t or don’t want to build lxd from master, I recommend waiting for next 3.0.1 release which will happen soon (stgraber might have a more concrete date in mind).
