Thank you so much for the reply,
Yes, all the traffic is traversing over the same physical interface which is eno1 51.89.223.107 at machine level
As mentioned - ubuntu focal as Host machine
lxc network attach-profile lxdbr0 default 51.89.233.107
objective is to assign pubic IP for each container and provide to the different teams/host different applications. Purchased block of 16 IP addresses 51.195.168.16/28 that will be routed via ns3163697.ip-51-89-233.eu that is from 51.89.233.107
added to the routing table as below,
ip -4 route add 51.195.168.16/28 dev lxdbr0
(this totally adds all 16 IPs from 51.195.168.16 - 51.195.168.31)
Created lxd container ubuntu and used netplan and configured 51.195.168.16 and able to ping from this server to external and from external to this server- perfectly working as expected
But iam stuck to achieve the me with centos, as manual steps are involved and request the experts support here, please find the below details mentioning that executed at host hypervisor and those executed with the container
-------------------root@ns3163697:~# lxc network show lxdbr0------------------------------------
in ubuntu linux hypervisor machine
ipv4.address: 10.192.120.1/24
ipv4.nat: âtrueâ
ipv6.address: fd42:f3e3:9bff:fc2f::1/64
ipv6.nat: âtrueâ
description: ââ
type: bridge
- /1.0/instances/centos8
- /1.0/instances/i1focal
- /1.0/instances/i2focal
- /1.0/instances/still-manatee
- /1.0/instances/u1
- /1.0/instances/u2
- /1.0/instances/u3
- /1.0/instances/u4
- /1.0/instances/u5
- /1.0/instances/u6focal
- /1.0/instances/u7focal
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
Note: the above i1focal, i2focal and u2 all are assigned with public IP as these are ubuntu contaniers which supports netplan.
--------------lxc profile show default------------------------------
root@ns3163697:~# lxc profile show default
config: {}
nictype: bridged
parent: lxdbr0
network: lxdbr0
pool: default
- /1.0/instances/u5
- /1.0/instances/u1
- /1.0/instances/u2
- /1.0/instances/u3
- /1.0/instances/u4
----------------------------------------End-------------------
---------------------------root@ns3163697:~# ip a-------------
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether ac:1f:6b:d4:63:ea brd ff:ff:ff:ff:ff:ff
inet 51.89.233.107/24 brd 51.89.233.255 scope global dynamic eno1
valid_lft 78920sec preferred_lft 78920sec
inet6 2001:41d0:800:266b::/56 scope global
inet6 fe80::ae1f:6bff:fed4:63ea/64 scope link
3: eno2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether ac:1f:6b:d4:63:eb brd ff:ff:ff:ff:ff:ff
4: lxcbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 00:16:3e:00:00:00 brd ff:ff:ff:ff:ff:ff
inet 10.0.3.1/24 scope global lxcbr0
5: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:e4:0e:93 brd ff:ff:ff:ff:ff:ff
inet 10.192.120.1/24 scope global lxdbr0
inet6 fd42:f3e3:9bff:fc2f::1/64 scope global
inet6 fe80::216:3eff:fee4:e93/64 scope link
27: veth2364ac98@if26: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether a6:3b:40:b4:c4:79 brd ff:ff:ff:ff:ff:ff link-netnsid 0
29: veth0d51e834@if28: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 46:39:5c:d0:5e:6a brd ff:ff:ff:ff:ff:ff link-netnsid 0
31: veth22facd9c@if30: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether ce:da:2e:eb:70:8f brd ff:ff:ff:ff:ff:ff link-netnsid 1
33: veth1ee76a59@if32: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether ce:4e:0a:a2:9c:0b brd ff:ff:ff:ff:ff:ff link-netnsid 1
35: veth30d9047b@if34: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 46:52:15:15:25:7b brd ff:ff:ff:ff:ff:ff link-netnsid 4
37: veth8582c575@if36: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 5a:c2:89:32:92:b5 brd ff:ff:ff:ff:ff:ff link-netnsid 4
51: veth23871d9d@if50: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether e2:3c:54:9a:4b:93 brd ff:ff:ff:ff:ff:ff link-netnsid 3
53: vethf5b519b9@if52: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 6a:fe:a6:b9:5b:ba brd ff:ff:ff:ff:ff:ff link-netnsid 3
55: veth5b3164e7@if54: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether aa:8d:27:74:06:83 brd ff:ff:ff:ff:ff:ff link-netnsid 5
57: veth0a8f2c09@if56: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether c6:df:6d:65:19:fd brd ff:ff:ff:ff:ff:ff link-netnsid 5
59: vethf3d4d4bf@if58: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 96:b2:c4:b8:42:64 brd ff:ff:ff:ff:ff:ff link-netnsid 6
61: veth365c0187@if60: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether ce:48:b8:0f:91:58 brd ff:ff:ff:ff:ff:ff link-netnsid 6
67: veth902b6e37@if66: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 8e:e6:22:4d:6f:41 brd ff:ff:ff:ff:ff:ff link-netnsid 7
69: veth55404c4d@if68: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 9a:a1:f7:49:28:ba brd ff:ff:ff:ff:ff:ff link-netnsid 7
71: vethd0bcff40@if70: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether ce:c2:4d:f0:ec:66 brd ff:ff:ff:ff:ff:ff link-netnsid 8
73: vetha8391924@if72: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 72:f4:c6:9d:45:2f brd ff:ff:ff:ff:ff:ff link-netnsid 8
79: veth2580d966@if78: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether aa:e6:db:8d:72:5e brd ff:ff:ff:ff:ff:ff link-netnsid 9
81: vetha7a8af5a@if80: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 7a:f2:ef:f0:4c:f2 brd ff:ff:ff:ff:ff:ff link-netnsid 9
99: vethfea65301@if98: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether d2:a9:48:56:29:53 brd ff:ff:ff:ff:ff:ff link-netnsid 10
101: veth6e2bbbab@if100: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 46:31:7d:22:8e:ee brd ff:ff:ff:ff:ff:ff link-netnsid 10
root@ns3163697:~#
--------------- ip r---------------------
root@ns3163697:~# ip r
default via 51.89.233.254 dev eno1 proto dhcp src 51.89.233.107 metric 100
10.0.3.0/24 dev lxcbr0 proto kernel scope link src 10.0.3.1 linkdown
10.192.120.0/24 dev lxdbr0 proto kernel scope link src 10.192.120.1
51.89.233.0/24 dev eno1 proto kernel scope link src 51.89.233.107
51.89.233.254 dev eno1 proto dhcp scope link src 51.89.233.107 metric 100
51.195.168.16/28 dev lxdbr0 scope link
root@ns3163697:~#
--------------------------------end -----------------
---------Below is ifcfg-a output from ubuntu focal-hyperviosor --------------------
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 51.89.233.107 netmask 255.255.255.0 broadcast 51.89.233.255
inet6 fe80::ae1f:6bff:fed4:63ea prefixlen 64 scopeid 0x20
inet6 2001:41d0:800:266b:: prefixlen 56 scopeid 0x0
ether ac:1f:6b:d4:63:ea txqueuelen 1000 (Ethernet)
RX packets 7438618 bytes 3180308850 (3.1 GB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 6543657 bytes 1269805031 (1.2 GB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eno2: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether ac:1f:6b:d4:63:eb txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 32 bytes 3436 (3.4 KB)
TX packets 32 bytes 3436 (3.4 KB)
lxcbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 10.0.3.1 netmask 255.255.255.0 broadcast 0.0.0.0
ether 00:16:3e:00:00:00 txqueuelen 1000 (Ethernet)
lxdbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.192.120.1 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 fd42:f3e3:9bff:fc2f::1 prefixlen 64 scopeid 0x0
inet6 fe80::216:3eff:fee4:e93 prefixlen 64 scopeid 0x20
ether 00:16:3e:e4:0e:93 txqueuelen 1000 (Ethernet)
RX packets 4378293 bytes 1135496760 (1.1 GB)
TX packets 5720406 bytes 2141456850 (2.1 GB)
veth0a8f2c09: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether c6:df:6d:65:19:fd txqueuelen 1000 (Ethernet)
RX packets 736987 bytes 376191120 (376.1 MB)
TX packets 2124204 bytes 709795469 (709.7 MB)
veth0d51e834: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 46:39:5c:d0:5e:6a txqueuelen 1000 (Ethernet)
RX packets 715412 bytes 128057517 (128.0 MB)
TX packets 2098011 bytes 150973955 (150.9 MB)
veth1ee76a59: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether ce:4e:0a:a2:9c:0b txqueuelen 1000 (Ethernet)
RX packets 291080 bytes 65322696 (65.3 MB)
TX packets 1732863 bytes 102660619 (102.6 MB)
veth22facd9c: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether ce:da:2e:eb:70:8f txqueuelen 1000 (Ethernet)
RX packets 9 bytes 766 (766.0 B)
TX packets 1429242 bytes 60919142 (60.9 MB)
veth2364ac98: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether a6:3b:40:b4:c4:79 txqueuelen 1000 (Ethernet)
TX packets 1432236 bytes 61047580 (61.0 MB)
veth23871d9d: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether e2:3c:54:9a:4b:93 txqueuelen 1000 (Ethernet)
TX packets 1389316 bytes 59231314 (59.2 MB)
veth2580d966: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether aa:e6:db:8d:72:5e txqueuelen 1000 (Ethernet)
TX packets 919307 bytes 39223004 (39.2 MB)
veth30d9047b: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 46:52:15:15:25:7b txqueuelen 1000 (Ethernet)
TX packets 1426944 bytes 60820710 (60.8 MB)
veth365c0187: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether ce:48:b8:0f:91:58 txqueuelen 1000 (Ethernet)
RX packets 245874 bytes 18969280 (18.9 MB)
TX packets 1647003 bytes 114121716 (114.1 MB)
veth55404c4d: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 9a:a1:f7:49:28:ba txqueuelen 1000 (Ethernet)
RX packets 206141 bytes 16107395 (16.1 MB)
TX packets 1606832 bytes 110142908 (110.1 MB)
veth5b3164e7: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether aa:8d:27:74:06:83 txqueuelen 1000 (Ethernet)
TX packets 1388227 bytes 59180510 (59.1 MB)
veth6e2bbbab: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 46:31:7d:22:8e:ee txqueuelen 1000 (Ethernet)
RX packets 183 bytes 18470 (18.4 KB)
TX packets 189136 bytes 8074094 (8.0 MB)
veth8582c575: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 5a:c2:89:32:92:b5 txqueuelen 1000 (Ethernet)
RX packets 915874 bytes 415706071 (415.7 MB)
TX packets 2274368 bytes 492915715 (492.9 MB)
veth902b6e37: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 8e:e6:22:4d:6f:41 txqueuelen 1000 (Ethernet)
TX packets 1384775 bytes 59016352 (59.0 MB)
vetha8391924: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 72:f4:c6:9d:45:2f txqueuelen 1000 (Ethernet)
RX packets 196048 bytes 14863934 (14.8 MB)
TX packets 1593656 bytes 106755509 (106.7 MB)
vetha7a8af5a: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 7a:f2:ef:f0:4c:f2 txqueuelen 1000 (Ethernet)
RX packets 165466 bytes 11913422 (11.9 MB)
TX packets 1093534 bytes 82852435 (82.8 MB)
vethd0bcff40: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether ce:c2:4d:f0:ec:66 txqueuelen 1000 (Ethernet)
TX packets 1381554 bytes 58877350 (58.8 MB)
vethf3d4d4bf: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 96:b2:c4:b8:42:64 txqueuelen 1000 (Ethernet)
TX packets 1386363 bytes 59095484 (59.0 MB)
vethf5b519b9: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 6a:fe:a6:b9:5b:ba txqueuelen 1000 (Ethernet)
RX packets 897068 bytes 146081292 (146.0 MB)
TX packets 2241748 bytes 725202280 (725.2 MB)
vethfea65301: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether d2:a9:48:56:29:53 txqueuelen 1000 (Ethernet)
RX packets 75 bytes 3538 (3.5 KB)
TX packets 189040 bytes 8059766 (8.0 MB)
---------------------------------------------end---------------------------
----------------------Below is output from the centos container ---------------------------------
In the centos container
[root@still-manatee ~]# ip addr show
98: eth1@if99: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:d6:5a:ef brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fd42:f3e3:9bff:fc2f:216:3eff:fed6:5aef/64 scope global mngtmpaddr dynamic
valid_lft 3526sec preferred_lft 3526sec
inet6 fe80::216:3eff:fed6:5aef/64 scope link
100: eth0@if101: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:b5:77:42 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.192.120.241/24 brd 10.192.120.255 scope global dynamic eth0
valid_lft 2769sec preferred_lft 2769sec
inet6 fd42:f3e3:9bff:fc2f:216:3eff:feb5:7742/64 scope global mngtmpaddr dynamic
inet6 fe80::216:3eff:feb5:7742/64 scope link
-----------------------------------------------------end----------------------------------------
