We are cloning lxc containers to another host in the same data center for backup purposes using lxc copy. To verify the content we need to bring it up but then there is IP addresses clash.
Is there any to modify the clone’s IP address without bringing it up ?
If you are using netplan/ifconfig or some other static ip’s inside of the container then you should be able to manipulate the files before bringing the new server up
