This tutorial shows how to compile and run Incus.
- It reinforces the instructions of the documentation.
- Shows how to create an Incus Debian VM,
images:debian/12, and compile in there the latest version of the source code from Github. - Discusses that it is important to use a recent Go. Gets a binary from the Go website. Shows what error you get if you do not get a recent Go compiler.
- Shows how to use the freshly installed Incus.
