For ex. mount inside something or change/add static Ip address, increase RAM, etc., without restart container?
lxc config
&& using profiles
to define what you need (prehaps cloud-init
look at the user.user-data
keys)
Are u confuse lxc and lxd? The question is about LXC, not LXD.
lxc-cgroup can do live cgroup updates.
The rest you’d need to do from the C API or using custom scripts.
Yeah, i can change RAM with lxc-cgroup
, but what about mount something or change IP? Did I understand correctly, there is no any command (for ex.: lxc-mount
or lxc-net
) to do that?
That’s correct, there is no such commands and in many cases, no C API for that either.
