Guys,
An awesome guy, @stgraber, just explained how to convert lxc.mount.entry
into a proper LXD config.
Now, I’m wondering if there is a similar solution for lxc.cgroup.devices.allow
For me Ceph OSD Containers, that I’m using with ceph-ansible
via openstack-ansible
, I need the following raw.lxc
too (otherwise, ceph-ansible
can’t create LVM2 volumes within the container):
raw.lxc: |-
lxc.cgroup.devices.allow = b 253:* rwm
lxc.mount.entry=/proc/sys/vm proc/sys/vm proc bind,rw 0 0
lxc.mount.entry=/proc/sys/fs proc/sys/fs proc bind,rw 0 0
Now I know how to use type disks
to replace those “lxc.mount.entry”…
Do you guys have another magic block for the “lxc.cgroup.devices.allow”?! I would LOVE that! LOL
Thank you!
