Hello to everyone.
I’m on the jetson nano,where I have installed ubuntu 22.04 and lxc (via snap). At this point,I have installed ubuntu 20.04 as container and I have enabled the network using the following commands :
lxc launch ubuntu:20.04 focal
lxc start focal
lxc exec focal -- dhclient
as you can see it is running correctly :
root@marietto-nano:/home/marietto/Scaricati/Docker/ub20# lxc list
| focal | RUNNING | 10.234.85.232 (eth0) | | CONTAINER | 0 |
root@marietto-nano:/home/marietto/Scaricati/Docker/ub20# lxc exec focal -- bash
root@focal:~# cd /etc/apt
root@focal:/etc/apt# ls
apt.conf.d auth.conf.d preferences.d sources.list sources.list.d trusted.gpg.d
root@focal:/etc/apt# apt update
Metadata [116 B]
Fetched 21.4 MB in 8s (2743 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
4 packages can be upgraded. Run 'apt list --upgradable' to see them.
root@focal:/etc/apt# apt upgrade
Calculating upgrade... Done
The following packages will be upgraded:
cloud-init libssl1.1 openssl tzdata
4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 standard LTS security updates
Need to get 2595 kB of archives.
After this operation, 209 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
ok. I stopped here the configuration of ubuntu 20.04 within the container,because previously I have already configured the ubuntu 20.04 installation that I want to use within the container. These files are stored inside the directory /20-new. What I want to do is to copy all these files inside the lxc container (called focal) and try to use it. But,unfortunately,I have some troubles. First of all I don’t understand what’s the path that leads me to those files. Maybe I found it,but there I see only broken links which makes me suspect that maybe something is wrong. I have attached all the pics of the broken links that I found on the system :
https://ibb.co/7KQkxZr
https://ibb.co/GJLWjXd
https://ibb.co/0jXQDWP
https://ibb.co/VjCNfG5
PS : in italian language : collegamento interrotto = broken link
thanks.
