I have a problem, I want to create 2 containers :
- First container with Nginx and PHP
- Second container with MySQL and Wordpress
But I don’t know how to do this.
Thanks in advance.
Thanks in advance.
Almost forgot: Do you really mean LXC?
Or LXD?
LXD is a lot easier to use imo.
Start with the getting started guide: https://linuxcontainers.org/lxd/getting-started-cli/
All you need for this is bascially:
For network access between containers it should be sufficient to add them to the same network .
Thanks for this information but I use Proxmox, can I create this with Proxmox ?
Edit: See answer from stgraber below:
Proxmox wraps around LXC much the same way LXD does, the end user doesn’t directly interact with LXC.
I don’t really see what the problem here is.
Just create two containers, install the services you wish in whatever container.
Proxmox should provide images for some of the most common distributions, then follow the instructions from whatever distribution you chose to actually install those services.
Most often this just involves installing packages with apt-get
or similar tooling, just as you would inside a virtual machine or a physical server.
Interesting, ok then @Ragna you should look at proxmox documentation and ask further questions there .
