How to disable auto start for all containers
How to disable auto start for all containers as default
Hi!
If this is a LXC question and not an LXD question (see https://blog.simos.info/comparison-between-lxc-and-lxd/), then you can set lxc.start.auto to 0. See more at https://linuxcontainers.org/lxc/manpages/man1/lxc-autostart.1.html
If instead you use LXD, you can get a list with all your containers with the following command.
lxc list --format=json | jq --raw-output '.[].name'
Then, for each container, you can run
lxc config set mycontainer boot.autostart false
so there is no default setting
You are asking how to change the default setting in LXD so that any newly created container does not autostart.
In that case, you set boot.autostart to false in your default profile.
$ lxc profile set default boot.autostart=false
$ lxc profile get default boot.autostart
false
$ lxc launch ubuntu:18.04 mycontainer
$ lxc config show mycontainer --expanded
  boot.autostart: "false"
Thanks
Hi, I’m trying to do this on lxd 4.0.9, but it doesn’t seem to be working. I have set the boot.autostart key to false in the default profile, and verified this with lxc profile get. However, when I launch a new container, it doesn’t seem to respect this change:
$ lxc launch ubuntu:20.04 mycontainer
$ lxc config get mycontainer boot.autostart
<no output>
That’s normal, look at lxc config get --expanded to get the config with profiles applied, otherwise it just queries the instance specific config.
