How to disable multicast snooping on bridges
Title says it all.
I have a few Incus bridges where I need to disable multicast snooping as they’re causing long delays in NDP between containers.
How can I tell Incus to disable it?
We don’t have a config option for it, but you can likely set it through /sys/class/net/incusbr0/bridge/multicast_snooping or equivalent, unless you’re on something locked down like IncusOS.
Thanks @stgraber ! I was looking at setting it at the OS level, but I’m also planning to move to IncusOS. Is this a planned feature? Should I open a ticket somewhere to request it if not?
Yeah, feel free to file a feature request against Incus. We can probably add an ipv6.multicast_snooping type config for this.
Created! Add option to disable multicast_snooping on bridges · Issue #3294 · lxc/incus · GitHub
