I’m having an issue where I need to start xorg and its accompanying display manager (LightDM, within context of Xubuntu) at the startup of an LXC container. I installed Xubuntu form a base Ubuntu Proxmox container installation via tasksel install xubuntu-desktop
. I then was able to install x2go (apt install x2goserver
) and start sessions for users just fine.
LightDM is installed, but it doesn’t seem to want to start at startup. I figure lightdm
is the right way to go since I would be able to use autologin and then execute a graphical app I need to start at system startup, but it seems like I’m missing some piece of the puzzle that get’s lightdm
to start at system startup on a container.
What’s preventing lightdm
from starting in an LXC instance? Is it the lack of a graphical terminal available by default? If so, what would be a workaround for this such that perhaps it renders to /dev/null until properly captured for user interaction via x2go (NX3)?
