Not sure whether this is the expected behaviour:
# lxd --version
5.13
# lxc network show ovn1
bridge.mtu: "1442"
ipv4.address: 10.177.66.1/24
ipv4.dhcp: "true"
ipv4.nat: "true"
ipv4.nat.address: 10.208.133.19
network: UPLINK
volatile.network.ipv4.address: 10.208.133.21
type: ovn
- /1.0/instances/nc02
- /1.0/instances/nc03
- /1.0/profiles/default
managed: true
status: Created
locations:
- node01
- node02
- node03
# lxc ls
| nc02 | STOPPED | | | CONTAINER | 0 | node01 |
| nc03 | RUNNING | 10.177.66.2 (eth0) | | CONTAINER | 0 | node02 |
# lxc start nc02
# lxc ls
| nc02 | RUNNING | 10.177.66.4 (eth0) | | CONTAINER | 0 | node01 |
| nfs-server | STOPPED | | | CONTAINER | 0 | node03 |
# lxc stop nc03
# lxc stop nc02
# lxc start nc02
# lxc ls
| nc02 | RUNNING | 10.177.66.2 (eth0) | | CONTAINER | 0 | node01 |
| nc03 | STOPPED | | | CONTAINER | 0 | node02 |
The IP is not the same after the reboot. It’s a different behaviour with respect to a “normal” network.
I’m using the Ubuntu jammy amd64 (20230523_07:42) image (id: a7e10bb9212b).
