jsieler
(jsieler)
May 6, 2020, 11:13am
1
Hello, i have following problem:
My host is Debian 10 (176.12.0.1), running last LXC with multiple containers. One of them running NGINX web server (176.12.0.50). To access the NGINX i do port forward with iptables, as follows:
iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j DNAT --to-destination 172.16.0.50:80
iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 443 -j DNAT --to-destination 172.16.0.50:443
It’s working well, with only one little BIG problem, real user IP addresses are logged as 176.12.0.1.
Is there any way to pass users real IP to LXC container?
Thanks for every help!
tomp
(Thomas Parrott)
May 6, 2020, 11:19am
2
Please can you show the output of iptables-save.
jsieler
(jsieler)
May 6, 2020, 11:23am
3
Thanks for your reply!
There is IPTables:
# Generated by xtables-save v1.8.2 on Wed May 6 13:20:18 2020
*filter
:INPUT ACCEPT [471861:104766683]
:FORWARD ACCEPT [376994:3312461948]
:OUTPUT ACCEPT [538450:145073247]
-A FORWARD -d 172.16.0.50/32 -p tcp -m tcp --dport 443 -j ACCEPT
-A FORWARD -d 172.16.0.50/32 -p tcp -m tcp --dport 80 -j ACCEPT
COMMIT
# Completed on Wed May 6 13:20:18 2020
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
-A PREROUTING -d 116.XXX.XXX.XXX/32 -i eth0 -p tcp -m tcp --dport 80 -j DNAT --to-destination 172.16.0.50:80
-A PREROUTING -d 116.XXX.XXX.XXX/32 -i eth0 -p tcp -m tcp --dport 443 -j DNAT --to-destination 172.16.0.50:443
-A PREROUTING -s 138.XXX.XXX.XXX/32 -i eth0 -p tcp -m tcp --dport 29015 -j DNAT --to-destination 172.16.0.10:29015
-A PREROUTING -s 138.XXX.XXX.XXX/32 -i eth0 -p tcp -m tcp --dport 28015 -j DNAT --to-destination 172.16.0.10:28015
-A PREROUTING -s 51.XXX.XXX.XXX/32 -i eth0 -p tcp -m tcp --dport 28015 -j DNAT --to-destination 172.16.0.10:28015
-A PREROUTING -i eth0 -p tcp -m tcp --dport 7788 -j DNAT --to-destination 172.16.0.51:7788
-A PREROUTING -i eth0 -p udp -m udp --dport 7788 -j DNAT --to-destination 172.16.0.51:7788
-A POSTROUTING -o br0 -j MASQUERADE
-A POSTROUTING -s 172.16.0.0/24 ! -d 172.16.0.0/24 -j MASQUERADE
COMMIT
*mangle
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
-A POSTROUTING -o br0 -p udp -m udp --dport 68 -j CHECKSUM --checksum-fill
COMMIT
If requered, ip a output as well:
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether a8:a1:59:0f:0a:c4 brd ff:ff:ff:ff:ff:ff
inet 116.xxx.xxx.xxx/26 brd 116.xxx.xxx.xxx scope global eth0
3: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:00:00:00 brd ff:ff:ff:ff:ff:ff
inet 172.16.0.1/24 scope global br0
4: wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet 10.0.0.1/24 scope global wg0
32: vethRKPSYX@if31: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether fe:d2:de:65:06:aa brd ff:ff:ff:ff:ff:ff link-netnsid 0
34: veth9QTO34@if33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether fe:d7:0a:81:44:20 brd ff:ff:ff:ff:ff:ff link-netnsid 1
36: vethCJAYAU@if35: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether fe:98:5f:9a:44:4a brd ff:ff:ff:ff:ff:ff link-netnsid 2
46: vethK0DPNW@if45: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether fe:a0:98:c1:0d:2c brd ff:ff:ff:ff:ff:ff link-netnsid 3
50: veth4TBP4F@if49: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether fe:d5:9a:d8:98:8b brd ff:ff:ff:ff:ff:ff link-netnsid 4
Thanks!
tomp
(Thomas Parrott)
May 6, 2020, 11:28am
4
It is this line that is doing it. You’re asking iptables to SNAT to the host’s IP for all traffic going out of br0 (i.e leaving the host and going to the containers).
jsieler
(jsieler)
May 6, 2020, 11:42am
6
Okay, removing that line did the trick and i now see all users IP’s in the log.
Will it possibly break anything if i remove that line? Or should it be replaced by something else?
That one was automatically added by LXC-NET.
