How to import a linux machine from kvm to incus
Hi All
Playing with incus is a wonderfull world. Thanks .
Finally after learning incus I have the last problem to solve. Migration from a linux KVM using drbd+lvm to a new machine server running incus + drbd + lvm.
I saw a document here ( How to import physical or virtual machines to Incus instances - Incus documentation)
Is there any other source that I must learn to do it?
Sometimes english is a barrier.
Thanks in advanced
Nope, incus-migrate should be the way to go here, it should let you import your existing VM disks into new Incus VMs.
Thnaks for your return Graber.
I’ll open another ticket with migration error
Thanks
