based on the blog post OpenBSD in LXD by Tobias Heider, after setting up the container, I am not able to start it. Instead, I get the following error message:
Error: Failed to handle idmapped storage: No such file or directory: “/mnt/stateful/lxd/storage-pools/default/containers/openbsd/rootfs”
Did someone try something similar and point me towards a solution?
Also, I am able to start other images, e.g. an Alpine Linux container from images.linuxcontainers.org. This question is about local images created inside crosh.
OpenBSD doesn’t provide an LXC container itself - I started from scratch:
$ lxc init openbsd --empty -c limits.cpu=4 -c limits.memory=4GiB
$ lxc config device override openbsd root size=20GiB size.state=4GiB
$ cd /tmp && curl -O https://cdn.openbsd.org/pub/OpenBSD/7.4/amd64/install74.img
$ lxc config device add openbsd install disk source=/tmp/install74.img boot.priority=10
At this point I should be ready to start the OpenBSD container.
(termina) chronos@localhost /tmp $ lxc start openbsd
Error: Failed to handle idmapped storage: No such file or directory: "/mnt/stateful/lxd/storage-pools/default/containers/openbsd/rootfs"
Try `lxc info --show-log openbsd` for more info
(termina) chronos@localhost /tmp $ lxc info --show-log openbsd
Status: STOPPED
Type: container
Created: 2024/03/14 21:54 CET
Log:
I didn’t get any log messages.
(termina) chronos@localhost /tmp $ lxc list
| alpine-edge | STOPPED | | | CONTAINER | 0 |
| openbsd | STOPPED | | | CONTAINER | 0 |
| penguin | RUNNING | 100.115.92.204 (eth0) | 2003:e7:1f02:8000:216:3eff:fef1:300a (eth0) | CONTAINER | 0 |
(termina) chronos@localhost /tmp $ lxc storage list
| default | btrfs | /mnt/stateful/lxd/storage-pools/default | | 8 | CREATED |
| obsb-pool | dir | /mnt/stateful/lxd/storage-pools/obsb-pool | | 0 | CREATED |
I also tried to move the openbsd image to another storage pool obsd-pool
but this didn’t solve anything for me.
Also, long `lxc info` output
config: {}
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- vsock_api
- storage_volumes_all_projects
- projects_networks_restricted_access
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- cpu_hotplug
api_status: stable
api_version: “1.0”
auth: trusted
public: false
auth_methods: - tls
environment:
addresses:
architectures:- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
driver: lxc
driver_version: 5.0.3
firewall: xtables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
idmapped_mounts: “true”
netnsid_getifaddrs: “true”
seccomp_listener: “true”
seccomp_listener_continue: “true”
shiftfs: “false”
uevent_injection: “true”
unpriv_fscaps: “true”
kernel_version: 6.1.60-08594-g03a802b9a072
lxc_features:
cgroup2: “true”
core_scheduling: “true”
devpts_fd: “true”
idmapped_mounts_v2: “true”
mount_injection_file: “true”
network_gateway_device_route: “true”
network_ipvlan: “true”
network_l2proxy: “true”
network_phys_macvlan_mtu: “true”
network_veth_router: “true”
pidfd: “true”
seccomp_allow_deny_syntax: “true”
seccomp_notify: “true”
seccomp_proxy_send_notify_fd: “true”
os_name: Chromium OS
os_version: “120”
project: default
server: lxd
server_clustered: false
server_event_mode: full-mesh
server_name: localhost
server_pid: 203
server_version: 5.0.2
storage: btrfs | dir
storage_version: 5.4.1 | 1
storage_supported_drivers: - name: btrfs
version: 5.4.1
remote: false - name: dir
version: “1”
remote: false - name: lvm
version: 2.03.21(2) (2023-04-21) / 1.02.195 (2023-04-21) / 4.47.0
remote: false
