As in the title. I need a way to allow the softether to install /dev/vpn_se tap device.
$ lxc config device add CONTAINER_NAME tap unix-char path=/dev/net/vpn_se
Error: Failed to start device 'tap': The required device path doesn't exist and the major and minor settings are not specified
I use usermode lxd container.
