incus move <name> -s <pool> is really slow because it uses rsync with compression which is totally not needed on the same host.
Can I just cp -a /var/lib/incus/storage-pools/pool1/containers/ct1 /var/lib/incus/storage-pools/pool2/containers/ct1, update the symlink at /var/lib/incus/containers/ct1 and update the root device on the container config? Or is there more things I have to do?
