I want to mount directories into my unpriviledged LXC containers that are provided by mergerfs (FUSE) but I get the following error message:
lxc-start: test: ../src/lxc/utils.c: safe_mount: 1220 Permission denied - Failed to mount "/mnt/mergerfs/dir01" onto "/usr/lib/x86_64-linux-gnu/lxc/rootfs/mnt/dir01"
lxc-start: test: ../src/lxc/conf.c: mount_entry: 2439 Permission denied - Failed to mount "/mnt/mergerfs/dir01" on "/usr/lib/x86_64-linux-gnu/lxc/rootfs/mnt/dir01"
The mount entry in lxc config files look like:
lxc.mount.entry = /mnt/mergerfs/dir01 mnt/dir01 none rw,bind,create=dir 0 0
I have read in #706 that mounting FUSE file systems may fail due to different internal permission handling. Unfortunately, I couldn’t find a solution.
Is it possible to mount directories from FUSE file systems into unpriviledged LXC containers and if so, how can this be done?
I am using lxc v5.0.2 on Debian 12 (bookworm) with kernel 6.1.0-13-amd64.
