Hi.
I have just migrated my containers from a lvm storage to a (raid1) btrfs storage - on the same host.
I have used the lxc move command to do so.
But now I have some images and profiles in the lvm storage that I would also like to move to the btrfs storage - so I can eventually abandon the old lvm storage.
Is there a way to do so?
I see this is somewhat covered in How do I move an image from one storage pool to another?
But does that mean that the “images” will remain available, if I delete the old storage pool, because they’re not actually really in a pool per se?
And what about the profiles, which don’t seem to have a directory of their own?
I also see the question of the profiles somewhat covered in Move default storage location with profile
Which I interpret that I should duplicate the profiles, but that still leaves the question of getting the profiles to reside in the new pool?
I did:
lxc move firty --storage brpool00
For each container.
My storage pools are:
[root@asusi7 storage-pools]# lxc storage ls
| brpool00 | btrfs | 7115d9f6-f852-43a9-a626-3870e74596e8 | | 24 | CREATED |
| defnew | lvm | defnew | | 4 | CREATED |
With defnew being the old and brpool00 the new one.
[root@asusi7 storage-pools]# lxc storage show defnew
lvm.thinpool_name: LXDThinPool
lvm.vg_name: defnew
source: defnew
volatile.initial_source: /dev/sdb5
driver: lvm
- /1.0/images/524f749ce98abd92ea3c8badd01a66cf8baa1daef5054516a4f60a27fb6a6c1e
- /1.0/profiles/default
- /1.0/profiles/newdef
- /1.0/profiles/only_disk
status: Created
locations:
- none
[root@asusi7 storage-pools]# lxc storage show brpool00
source: 7115d9f6-f852-43a9-a626-3870e74596e8
volatile.initial_source: 7115d9f6-f852-43a9-a626-3870e74596e8
driver: btrfs
- /1.0/instances/firty
... and more ...
status: Created
locations:
- none
So, you see the “residuals” - that I want to move - in the old pool are:
Does LXD have some notion of a “default” storage pool? If so, how can I change it to the new one?
The lVM uses thinpool (and by now it is also multidevice).
(BTW: I can’t remember’ what the image is for - or if it still required).
If necessary I can endure the pain of duplicating the profiles to the new pool and reassigning them to the containers. (Before abandonment).
This is on Fedora 39 - and snap is not installed.
I hope this makes sense, and that I have provided proper information.
Kind regards, Jakob.
