Hi
I want to use named fifo for host to container commucation,so i do these try:
- run
mkfifoon host to make a named fifo in /root/fifo - add following line to container config file
lxc.mount.entry = /root/pipe dev/pipe none optional,create=file
3.start the container
container can be started successfully,and there is a pipe under /dev,but looks as if this pipe just a normal file,not a linux named pipe
so is there any way to do this ?
Thanks
