How to provide internet access inside container using bridge or nat?
I am using lxc-net helper script to create lxcbr0 interface. The container gets ip address but internet is not accessible (ping 8.8.8.8 doesn’t work).
The host is connected via wifi (no ethernet ports). How can I get internet access in the host ? I don’t mind if the host and container cannot ping each other.
Host :
sudo ip a show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
    inet6 ::1/128 scope host
2: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN qlen 1000
    link/ether 7e:44:f6:7d:a3:6a brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
    link/ether 9e:a8:78:c2:6f:aa brd ff:ff:ff:ff:ff:ff
    inet 192.168.182.153/24 brd 192.168.182.255 scope global dynamic noprefixroute wlan0
       valid_lft 2986sec preferred_lft 2986sec
    inet6 2409:40c1:100b:73ec:1a4:8060:6eb0:eac9/64 scope global secondary dynamic
       valid_lft 6968sec preferred_lft 6968sec
    inet6 2409:40c1:100b:73ec:8116:18fe:aba:d0b1/64 scope global dynamic noprefixroute flags 100
    inet6 fe80::98ce:42d1:1fc2:16f2/64 scope link noprefixroute
4: lxcbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
    link/ether 00:16:3e:00:00:00 brd ff:ff:ff:ff:ff:ff
    inet 10.0.3.1/24 scope global lxcbr0
    inet6 fe80::216:3eff:fe00:0/64 scope link
5: wwan0: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN qlen 1000
    link/[519]
6: wwan1: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN qlen 1000
    link/[519]
7: wwan2: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN qlen 1000
    link/[519]
8: wwan3: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN qlen 1000
    link/[519]
9: wwan4: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN qlen 1000
    link/[519]
10: wwan5: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN qlen 1000
    link/[519]
11: wwan6: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN qlen 1000
    link/[519]
12: wwan7: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN qlen 1000
    link/[519]
13: vethoIpQFm@usb0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxcbr0 state UP qlen 1000
    link/ether fe:9c:b4:33:51:7c brd ff:ff:ff:ff:ff:ff
    inet6 fe80::fc9c:b4ff:fe33:517c/64 scope link
sudo brctl show
bridge name     bridge id               STP enabled     interfaces
lxcbr0          8000.00163e000000       no              vethoIpQFm
sudo cat /var/lib/lxc/swizzin/config
# Template used to create this container: /usr/share/lxc/templates/lxc-download
# Parameters passed to the template:
#lxc.include = /usr/share/lxc/config/nesting.conf
# Distribution configuration
lxc.arch = linux64
lxc.rootfs.path = dir:/var/lib/lxc/swizzin/rootfs
lxc.uts.name = swizzin
# Network configuration
lxc.net.0.type = veth
lxc.net.0.link = lxcbr0
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3e:79:63:8c
#lxc.net.0.ipv4.address = 192.168.1.111/24
#lxc.net.0.ipv4.gateway = 192.168.1.1
sudo lxc-checkconfig
LXC version 5.0.3
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Warning: newuidmap is not setuid-root
Warning: newgidmap is not setuid-root
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup namespace: enabled
Cgroup v1 mount points:
Cgroup v2 mount points:
 - /sys/fs/cgroup
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
--- Misc ---
Macvlan: enabled, not loaded
Vlan: enabled, not loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, loaded
FUSE (for use with lxcfs): enabled, not loaded
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: missing
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: missing
CONFIG_NETLINK_DIAG: missing
File capabilities: enabled
sudo iptables -L -n -v
Chain INPUT (policy ACCEPT 762 packets, 62023 bytes)
 pkts bytes target     prot opt in     out     source               destination
    0     0 ACCEPT     6    --  lxcbr0 *       0.0.0.0/0            0.0.0.0/0            tcp dpt:53
    0     0 ACCEPT     17   --  lxcbr0 *       0.0.0.0/0            0.0.0.0/0            udp dpt:53
    0     0 ACCEPT     6    --  lxcbr0 *       0.0.0.0/0            0.0.0.0/0            tcp dpt:67
    2   626 ACCEPT     17   --  lxcbr0 *       0.0.0.0/0            0.0.0.0/0            udp dpt:67
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
    0     0 ACCEPT     0    --  *      lxcbr0  0.0.0.0/0            0.0.0.0/0
    0     0 ACCEPT     0    --  lxcbr0 *       0.0.0.0/0            0.0.0.0/0
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
cat /etc/os-release
PRETTY_NAME="postmarketOS edge"
NAME="postmarketOS"
VERSION_ID="edge"
VERSION="edge"
ID="postmarketos"
ID_LIKE="alpine"
HOME_URL="https://www.postmarketos.org/"
SUPPORT_URL="https://gitlab.com/postmarketOS"
BUG_REPORT_URL="https://gitlab.com/postmarketOS/pmaports/issues"
LOGO="postmarketos-logo"
uname -a
Linux fortuna3g 6.6.0-msm8916 #4 SMP PREEMPT Tue Mar 26 11:28:06 UTC 2024 aarch64 Linux
Container :
ping 8.8.8.8 does not work but ping to host works.
sudo ip a show
2: eth0@if13: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:16:3e:79:63:8c brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet 10.0.3.3/24 metric 100 brd 10.0.3.255 scope global dynamic eth0
       valid_lft 2661sec preferred_lft 2661sec
    inet6 fe80::216:3eff:fe79:638c/64 scope link
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.4 LTS
Release:        22.04
Codename:       jammy
uname -r
6.6.0-msm8916
Nevermind, it was nftables that was blocking internet access.
Could you post your full solution?
It helps people that are searching for a solution for the same or similar issue.
Plus, I am curious. :smile:
