In the following an example is shared on how I think one can insure a LXD infrastructure against a desaster. Since I am not an expert of either LXD nor btrbk yet comments on what can be done better are very welcome. In particular i’d be interested to know how recovering of configurations (“lxc config”, “lxc profile” and “lxc network”) could be done other than by typing single commands.
Setup
The setup consists of two hosts one is called debian the other appenzeller. On host appenzeller backups of snapshots from host debian are stored. LXD runs on host debian:
root@debian:~# cat /etc/os-release | grep -i pretty
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
LXD is installed by snap:
root@debian:~# snap list
core20 20220826 1623 latest/stable canonical✓ base
lxd 5.5-37534be 23537 latest/stable canonical✓ -
snapd 2.57.1 16778 latest/stable canonical✓ snapd
btrfs is used as filesystem and the LXD installation resides on its own subvolume:
root@debian:~# btrfs subvolume list /
ID 256 gen 15182 top level 5 path @rootfs
ID 260 gen 15180 top level 5 path @lxd
ID 538 gen 14292 top level 260 path @lxd/common/lxd/storage-pools/lxdstorage1
ID 541 gen 15177 top level 538 path @lxd/common/lxd/storage-pools/lxdstorage1/containers/hww
lxd was initialized as shown in the listing below.
root@debian:~# lxd init
Would you like to use LXD clustering? (yes/no) [default=no]:
Name of the new storage pool [default=default]: lxdstorage1
Name of the storage backend to use (btrfs, dir, lvm, ceph) [default=btrfs]:
Would you like to create a new btrfs subvolume under /var/snap/lxd/common/lxd? (yes/no) [default=yes]:
Would you like to create a new local network bridge? (yes/no) [default=yes]:
What should the new bridge be called? [default=lxdbr0]:
Would you like the LXD server to be available over the network? (yes/no) [default=no]: no
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]:
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]:
There is one container called hww (Hello-World-Webserver):
root@debian:~# lxc list
| hww | RUNNING | 10.64.187.39 (eth0) | fd42:Blah | CONTAINER | 0 |
As a backup tool btrbk is used. The configuration of btrbk is:
root@debian:~# cat /root/btrbk.1.config
timestamp_format long
preserve_day_of_week thursday
preserve_hour_of_day 16
snapshot_preserve_min latest
# Keep
# - hourly: 24 hours
# - daily: 30 days
# - weekly: 4 weeks
# - monthly: 12 month
target_preserve 24h 30d 4w 12m
ssh_identity /root/appenzeller
volume /var/snap/lxd/
subvolume common/lxd/storage-pools/lxdstorage1
target ssh://appenzeller/data/btrbk
subvolume common/lxd/storage-pools/lxdstorage1/containers/hww
Comment to the btrbk configuration: Snapshots are stored as backups on a remote host. Appenzeller is a Swiss alcoholic drink which doesn’t matter here. For further documentation on btrbk see btrbk - README. I find it a quite cool piece of software! btrbk can be run like listed below:
root@debian:~# btrbk -c btrbk.1.config run
This creates snapshots of lxdstorage1 and hww on host debian:
root@debian:~# btrbk ls / | grep 20220909T0923
/dev/sda1 268 readonly /var/snap/lxd/hww.20220909T0923
/dev/sda1 267 readonly /var/snap/lxd/lxdstorage1.20220909T0923
And backups of the snapshots on host appenzeller:
root@appenzeller:~# btrfs subvolume list / | grep 20220909T0923
ID 266 gen 5282 top level 256 path data/btrbk/hww.20220909T0923
ID 268 gen 5279 top level 256 path data/btrbk/lxdstorage1.20220909T0923
Creating a Desaster
To simulate a desaster lxd is removed from host debian. First LXD is shut down:
root@debian:~# lxd shutdown
LXD is removed to the best of my knowledge in two steps:
root@debian:~# snap remove lxd --purge
error: cannot perform the following tasks: ...snip...
- Remove data for snap "lxd" (23537) (failed to remove snap\
"lxd" base directory: remove /var/snap/lxd: device or resource busy)
root@debian:~# umount /var/snap/lxd
lxd removed
Now, LXD is removed from host debian:
core20 20220805 1611 latest/stable canonical✓ base
snapd 2.56.2 16292 latest/stable canonical✓ snapd
What’s left on /var/snap/lxd are only the two snapshots hww.20220909T0923 and lxdstorage1.20220909T0923 to keep this showcase simple. In a real desaster they would have to be sent from host appenzeller to host debian first (see btrbk - README):
root@debian:~# ls /var/snap/lxd/
hww.20220909T0923 lxdstorage1.20220909T0923
Now, the desaster is created. Next steps show how to recover from snapshots hww.20220909T0923 and lxdstorage1.20220909T0923.
Recover from Disaster
Well, first LXD is again installed on host debian:
root@debian:~# snap install lxd
lxd 5.5-37534be from Canonical✓ installed
23537 common current hww.20220909T0923 lxdstorage1.20220909T0923
Next, subvolume lxdstorage1 is restored:
root@debian:~# mkdir /var/snap/lxd/common/lxd/storage-pools
root@debian:~# btrfs send /var/snap/lxd/lxdstorage1.20220909T0923\
| btrfs receive\
At subvol /var/snap/lxd/lxdstorage1.20220909T0923
At subvol lxdstorage1.20220909T0923
root@debian:/var/snap/lxd/common/lxd/storage-pools# btrfs\
subvolume snapshot lxdstorage1.20220909T0923 lxdstorage1
Create a snapshot of 'lxdstorage1.20220909T0923' in './lxdstorage1'
And the same has to be done for hww:
root@debian:~# btrfs send /var/snap/lxd/hww.20220909T0923 \
| btrfs receive\
/var/snap/lxd/common/lxd/storage-pools/lxdstorage1/containers
At subvol /var/snap/lxd/hww.20220909T0923
At subvol hww.20220909T0923
root@debian:/var/snap/lxd/common/lxd/storage-pools/lxdstorage1/containers# btrfs\
subvolume snapshot hww.20220909T0923 hww
Then, delete the snapshots in the storage directory:
subvolume delete hww.20220909T0923
Delete subvolume (no-commit):\
'/var/snap/lxd/common/lxd/storage-pools/lxdstorage1/containers/hww.20220909T0923'
subvolume delete lxdstorage1.20220909T0923
'/var/snap/lxd/common/lxd/storage-pools/lxdstorage1.20220909T0923'
Next, “lxd recover” does its good work:
root@debian:~# lxd recover
This LXD server currently has the following storage pools:
Would you like to recover another storage pool? (yes/no) [default=no]: yes
Name of the storage pool: lxdstorage1
Name of the storage backend (btrfs, ceph, cephfs, cephobject, dir, lvm): btrfs
Source of the storage pool (block device, volume group, dataset, path, ... as applicable): /var/snap/lxd/common/lxd/storage-pools/lxdstorage1
Additional storage pool configuration property (KEY=VALUE, empty when done):
The recovery process will be scanning the following storage pools:
- NEW: "lxdstorage1" (backend="btrfs", source="/var/snap/lxd/common/lxd/storage-pools/lxdstorage1")
Would you like to continue with scanning for lost volumes? (yes/no) [default=yes]:
Scanning for unknown volumes...
The following unknown volumes have been found:
- Container "hww" on pool "lxdstorage1" in project "default" (includes 0 snapshots)
You are currently missing the following:
- Network "lxdbr0" in project "default"
This tells us that lxbr0 has to be created:
root@debian:~# lxc network create lxdbr0
If this is your first time running LXD on this machine, you should also run: lxd init
To start your first container, try: lxc launch ubuntu:22.04
Or for a virtual machine: lxc launch ubuntu:22.04 --vm
Network lxdbr0 created
root@debian:~# lxc network info lxdbr0
MAC address: 00:16:3e:b4:62:3c
MTU: 1500
State: up
Type: broadcast
IP addresses:
inet 10.64.187.1/24 (global)
inet6 fd42:8dd4:9192:f461::1/64 (global)
Network usage:
Bytes received: 0B
Bytes sent: 0B
Packets received: 0
Packets sent: 0
Bridge:
STP: false
Forward delay: 1500
Default VLAN ID: 1
VLAN filtering: true
Upper devices:
After, that one can go on with the lxd recover process:
Please create those missing entries and then hit ENTER:
Would you like those to be recovered? (yes/no) [default=no]: yes
Starting recovery...
One also has to configure the default profile:
root@debian:~# lxc profile device add default root disk path=/ pool=lxdstorage1
root@debian:~# lxc profile device add default eth0 nic name=eth0 network=lxdbr0
root@debian:~# lxc profile show default
config: {}
network: lxdbr0
pool: lxdstorage1
- /1.0/instances/hww
Container hww Up and Running again
Now I could start hww again and everything seemed to be back to normal:
root@debian:~# lxc start hww
| hww | RUNNING | 10.64.187.39 (eth0) | ...snip... (eth0) | CONTAINER | 0 |
root@debian:~# wget -q 10.64.187.39 -O - | grep Hello
<title>Hello World Webserver</title>
<h1>Hello World Webserver</h1>
