I stored several container in a separate lxd-storage (btrfs).
The hole thing is located on a physical disk.
Today, the root-disk failed and I attached the lxd-disk to the backup-device.
I tried to restore the volumes on the new device, without success.
What I did:
lxd recover
Name of the storage pool: second
Name of the storage backend: btrfs
Source of the storage pool: /dev/sdb1
- EXISTING: "default" (backend="btrfs", source="/var/snap/lxd/common/lxd/disks/default.img")
- NEW: "second" (backend="btrfs", source="/dev/sdb1")
Error: Failed validation request: Failed checking volumes on pool "default":
Failed parsing backup file
"/var/snap/lxd/common/lxd/storage-pools/default/containers/migration.3209980035/backup.yaml":
open /var/snap/lxd/common/lxd/storage-pools/default/containers/migration.3209980035/backup.yaml:
no such file or directory
Any help to allocate the storage pool to the new device is highly appreciated.
Thanks.
I should delete anything in the folder /var/snap/lxd/common/lxd/storage-pools/default/containers ?
Now the »unknown volumes are found«
The following unknown volumes« have been found:
- Container "devel" on pool "second" in project "default" (includes 1 snapshots)
- Container "halfgarten" on pool "second" in project "default" (includes 0 snapshots)
- Container "hb" on pool "second" in project "default" (includes 0 snapshots) (...)
but then
failed creating instance "devel" record in project "default"
