This is a tutorial for end-users on running the desktop Incus images.
In a nutshell, you run them as follows. That is, you add --console=vga to get the Remote Viewer running. Also, you need to increase a bit the VM memory from the default 1GB. The Ubuntu image requires 1.2GB RAM
Access Denied means that you’re trying to boot an image that’s not valid according to your secureboot policy.
In the case of Arch Linux, that’s because it’s not signed for boot on SecureBoot systems, so you’ll need to turn it off with security.secureboot=false
