How to run OCI on Incus inside Incus?
I would like to run an OCI container inside an Incus container that has Incus installed.
(Normal Incus container inside the Incus container runs normally.)
Host: Ubuntu 24.04 - Incus LTS from zabbly
Incus-Container: Ubuntu 24.04 - Incus Stable 6.15 from zabbly
Storage: ZFS on both (From Ubuntu repos)
The commands I run inside the Incus-Container:
incus remote add docker https://docker.io --protocol=oci
incus launch docker:hello-world hello
Output:
Launching hello
Error: Failed instance creation: Failed to run: /opt/incus/bin/incusd forkstart hello /var/lib/incus/containers /run/incus/hello/lxc.conf: exit status 1
incus info --show-log hello
Description:
Status: STOPPED
Type: container (application)
Created: 2025/08/15 16:53 UTC
Last Used: 2025/08/15 17:07 UTC
Log:
lxc hello 20250815170743.636 ERROR    cgroup2_devices - ../src/lxc/cgroups/cgroup2_devices.c:bpf_program_load_kernel:332 - Operation not permitted - Failed to load bpf program: (null)
lxc hello 20250815170743.185 ERROR    conf - ../src/lxc/conf.c:setup_sysctl_parameters:3137 - Invalid argument - Failed to setup sysctl parameters net.ipv4.ping_group_range to 0 4294967294
lxc hello 20250815170743.185 ERROR    conf - ../src/lxc/conf.c:lxc_setup:4022 - Failed to setup sysctl parameters
lxc hello 20250815170743.186 ERROR    start - ../src/lxc/start.c:do_start:1273 - Failed to setup container "hello"
lxc hello 20250815170743.186 ERROR    sync - ../src/lxc/sync.c:sync_wait:34 - An error occurred in another process (expected sequence number 4)
lxc hello 20250815170743.186 WARN     network - ../src/lxc/network.c:lxc_delete_network_priv:3674 - Failed to rename interface with index 0 from "eth0" to its initial name "veth62b417df"
lxc hello 20250815170743.186 ERROR    lxccontainer - ../src/lxc/lxccontainer.c:wait_on_daemonized_start:837 - Received container state "ABORTING" instead of "RUNNING"
lxc hello 20250815170743.187 ERROR    start - ../src/lxc/start.c:__lxc_start:2119 - Failed to spawn container "hello"
lxc hello 20250815170743.188 WARN     start - ../src/lxc/start.c:lxc_abort:1037 - No such process - Failed to send SIGKILL via pidfd 18 for process 1802
lxc 20250815170743.265 ERROR    af_unix - ../src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20250815170743.266 ERROR    commands - ../src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_init_pid"
I have the following security settings already on the Incus-Container:
  security.idmap.isolated: "true"
  security.nesting: "true"
  security.syscalls.intercept.bpf: "true"
  security.syscalls.intercept.bpf.devices: "true"
  security.syscalls.intercept.mknod: "true"
  security.syscalls.intercept.setxattr: "true"
Which ones will I need @stgraber ?
Can you try security.privileged=true?
The error you’re getting is because net.ipv4.ping_group_range can’t be set due to the nested container’s idmap. Assuming the parent container is unprivileged, there’s no real reason to have the nested container use a sub-map.
Ah, actually the problem may be the other way around, your nested container may already be marked as privileged which then has Incus assume it can set the whole range (just looked at the code now).
Unfortunately it does not make a difference: (This is inside the first Incus-Container)
root@somehost:~# incus launch docker:hello-world hello7 -c security.privileged=true
Launching hello7
Error: Failed instance creation: Failed to run: /opt/incus/bin/incusd forkstart hello7 /var/lib/incus/containers /run/incus/hello7/lxc.conf: exit status 1
root@somehost:~# incus info --show-log hello7
Description:
Status: STOPPED
Created: 2025/08/15 18:32 UTC
Last Used: 2025/08/15 18:32 UTC
Log:
lxc hello7 20250815183222.552 ERROR    cgroup2_devices - ../src/lxc/cgroups/cgroup2_devices.c:bpf_program_load_kernel:332 - Operation not permitted - Failed to load bpf program: (null)
lxc hello7 20250815183222.618 ERROR    conf - ../src/lxc/conf.c:setup_sysctl_parameters:3137 - Invalid argument - Failed to setup sysctl parameters net.ipv4.ping_group_range to 0 4294967294
lxc hello7 20250815183222.618 ERROR    conf - ../src/lxc/conf.c:lxc_setup:4022 - Failed to setup sysctl parameters
lxc hello7 20250815183222.618 ERROR    start - ../src/lxc/start.c:do_start:1273 - Failed to setup container "hello7"
lxc hello7 20250815183222.618 ERROR    sync - ../src/lxc/sync.c:sync_wait:34 - An error occurred in another process (expected sequence number 4)
lxc hello7 20250815183222.618 WARN     network - ../src/lxc/network.c:lxc_delete_network_priv:3674 - Failed to rename interface with index 0 from "eth0" to its initial name "vethd277e491"
lxc hello7 20250815183222.618 ERROR    lxccontainer - ../src/lxc/lxccontainer.c:wait_on_daemonized_start:837 - Received container state "ABORTING" instead of "RUNNING"
lxc hello7 20250815183222.619 ERROR    start - ../src/lxc/start.c:__lxc_start:2119 - Failed to spawn container "hello7"
lxc hello7 20250815183222.619 WARN     start - ../src/lxc/start.c:lxc_abort:1037 - No such process - Failed to send SIGKILL via pidfd 18 for process 2368
lxc 20250815183222.690 ERROR    af_unix - ../src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20250815183222.690 ERROR    commands - ../src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_init_pid"
Can I fix it with the existing package of Incus I have?
There’s a good chance that the fix will get cherry-picked at some point next week, assuming there are other bugfixes we want to roll out to users before 6.16.
Ok, then I’ll have to use Docker or Podman for now. :confused:
Thank you so much for the quick fix! Wish you a wonderful weekend!
In what release will it be? :slight_smile:
It was cherry-picked last week into the Zabbly stable packages.
Otherwise Incus 6.16 will also include it (due out late tomorrow).
