davidfavor
(David Favor)
December 10, 2021, 3:30pm
1
Trying to get a static IP working for an Alpine container running on an Ubuntu Focal machine.
With Ubuntu containers, this is trivial by creating an /etc/netplan config file.
Someone pass along to me the equivalent config file setup for Alpine.
Current networking shows…
net13 # lxc list net13-template-alpine-315
| net13-template-alpine-315 | RUNNING | 10.130.226.112 (eth0) | fd42:f1b:cbe0:23be:216:3eff:fee6:a01e (eth1) | CONTAINER | 0 |
| | | | fd42:f1b:cbe0:23be:216:3eff:fe4f:1767 (eth0) | | |
Thanks!
tomp
(Thomas Parrott)
December 10, 2021, 5:41pm
2
Assuming the Alpine instance is using DHCP, you can create a static DHCP allocation using:
lxc config device override <instance> <interface> ipv4.address=n.n.n.n
davidfavor
(David Favor)
December 14, 2021, 4:35pm
3
Never have gotten any lxd config device syntax to work with any container, which is why I use /etc/netplan in Ubuntu containers.
Here’s error…
net13 # lxc config device override net13-template-alpine-315 eth0 ipv4.address=192.99.135.210
Error: The device already exists
davidfavor
(David Favor)
December 14, 2021, 4:36pm
4
Be great if someone can tell me how to do this inside the container, maybe through /etc/network/interfaces syntax.
tomp
(Thomas Parrott)
December 14, 2021, 4:42pm
5
Use set rather than override, as you can only override a device coming from a profile, but in this case the device must already be in the instance directly:
lxc config device set net13-template-alpine-315 eth0 ipv4.address=192.99.135.210
davidfavor
(David Favor)
December 14, 2021, 4:49pm
6
net13 # lxc config device set net13-template-alpine-315 eth0 ipv4.address=192.99.135.210
Error: Invalid devices: Device validation failed for "eth0": Device IP address "192.99.135.210" not within network "lxdbr0" subnet
tomp
(Thomas Parrott)
December 14, 2021, 4:51pm
7
Yep, thats probably true
You can’t instruct LXD to create a static DHCP allocation for an IP outside of the parent network’s subnet.
What does lxc network show lxdbr0 show?
davidfavor
(David Favor)
December 14, 2021, 6:16pm
8
ipv4.address: 10.130.226.1/24
ipv4.nat: "true"
ipv6.address: fd42:f1b:cbe0:23be::1/64
ipv6.nat: "true"
type: bridge
- /1.0/instances/net13-david-favor
- /1.0/instances/net13-david-favor-fixdeliver
- /1.0/instances/net13-dns-ns12-focal
- /1.0/instances/net13-fixdeliver-mta
- /1.0/instances/net13-hivelocity
- /1.0/instances/net13-jasites-author-projects
- /1.0/instances/net13-jasites-health-projects
- /1.0/instances/net13-joymta-v1
- /1.0/instances/net13-joymta-v2
- /1.0/instances/net13-template-alpine-315
- /1.0/instances/net13-template-focal
- /1.0/instances/net13-website-tester
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
davidfavor
(David Favor)
December 14, 2021, 6:17pm
9
Also here’s the routing table…
net13 # route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 54.39.133.254 0.0.0.0 UG 100 0 0 eno1
10.130.226.0 0.0.0.0 255.255.255.0 U 0 0 0 lxdbr0
54.39.133.0 0.0.0.0 255.255.255.0 U 0 0 0 eno1
54.39.133.254 0.0.0.0 255.255.255.255 UH 100 0 0 eno1
142.44.168.80 0.0.0.0 255.255.255.240 U 0 0 0 lxdbr0
192.99.135.208 0.0.0.0 255.255.255.240 U 0 0 0 lxdbr0
tomp
(Thomas Parrott)
December 14, 2021, 6:28pm
10
192.99.135.210 is not in the lxdbr0 subnet 10.130.226.0/24
davidfavor
(David Favor)
December 14, 2021, 6:30pm
11
Correct.
What’s required is 192.99.135.210 being set as the container’s static IP.
This is trivial with Ubuntu, just create an /etc/netplan file.
What I’m asking about is a similar trivial config for Alpine containers, which run old V1 networking, so /etc/network/interfaces is likely file to modify.
davidfavor
(David Favor)
December 15, 2021, 5:51pm
12
The following /etc/network/interfaces seems to work.
Someone let me know if this is the correct approach or there’s a better way.
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
hostname $(hostname)
auto eth1
iface eth1 inet static
address 192.99.135.210
netmask 255.255.255.0
gateway 10.130.226.1
Thanks!
davidfavor
(David Favor)
March 28, 2024, 1:38pm
13
Best fix seems to now be changing /etc/network/interfaces to the following…
auto eth0
auto eth0
iface eth0 inet static
address 198.50.215.210
For this to work host level routing must match LXD standard practices, so…
ip -4 route add 198.50.215.208/28 dev lxdbr0
So route + IP match…
