I have an LXD cluster and DNS/DHCP come from MAAS. Every container autoregister and gets IP from the MAAS. Default TLD is .lxd as usual. I need to create another project for example “client1” and tld I would to be different. So for default project tld = .lxd, for client1 project tld = .one. Is this possible?
You need a separate bridge in LXD for that, then set dns.domain to the value you want on that bridge.
Though I’m a bit confused by the MAAS part here. If MAAS handles DHCP/DNS for your instances, then it wouldn’t be getting a .lxd domain, it would get whatever the network is in MAAS instead.
