How to set volblocksize for a VM root on ZFS?
Recently I’ve discovered that the default volblocksize for zvols is 16KB. I want to run my VMs on zvols with volblocksize=128k. There’s an open issue in ZFS tracker to set volblocksize on a dataset level so it would be inherited by zvols, but until it’s implemented the size must be set in the software (incus). So I did some investigation and couldn’t find a way to set volblocksize for the root disks of VMs.
There’s a way to set the blocksize on the storage pool: incus storage set default volume.zfs.blocksize 131072. This makes all the new volumes get the proper value (128k). When a VM is started incus creates a zvol for the root disk in the same dataset, so I expected this value to apply to the root disks as well, alas it doesn’t.
I tried setting this value in the default profile: incus profile device set default root initial.zfs.blocksize=131072. This doesn’t work either: incus accepts this command, updates the profile, but this value is ignored for the new VMs.
So: is there a way to set the blocksize not only for volumes created by incus storage volume create, but also for automatically created root devices?
I’d have expected the initial.zfs.blocksize trick to work, can you check incus storage volume show default virtual-machine/NAME to see what ends up being set on the volume?
Did more testing: initial.zfs.blocksize doesn’t work. What works though is volume.zfs.blocksize for a storage, but there’s a trick: it must be set before an image is pulled. So I believe what happens is:
  1. When Incus creates a VM, it makes a quick copy of an image (existing zvol)
  2. The copy inherits volblocksize of the image and it’s not possible to override it via a config option
So, to make a VM use another volblocksize, you need to:
  1. Remove an existing image that was created with an old blocksize: incus image rm ...
  2. Set the desired blocksize: incus storage set default volume.zfs.blocksize 131072
  3. Create a VM: incus launch images:debian/13 test --vm
    So Incus would pull an image into a new zvol with the specified blocksize, and all the new VMs will inherit this value.
So this basically resolves my issue, I now can create VMs as I want them to be.
As for the initial.zfs.blocksize, found this in https://linuxcontainers.org/incus/docs/main/reference/devices_disk:
Note that you cannot use initial volume configurations with custom volume options or to set the volume’s size.
So it’s probably expected.
UPD: Here’s how it looks like: one old image and one new
~ ❯ zfs list -r -o name,volblocksize data/incus/images
NAME        VOLBLOCK
data/incus/images        -
data/incus/images/c20de1cbe2327627fe41db7833910f7b6c74c246528cbe9a81bff01ea9489b92               -
data/incus/images/c20de1cbe2327627fe41db7833910f7b6c74c246528cbe9a81bff01ea9489b92.block       16K
data/incus/images/cd8c3e41e84dd5105c9b7bfae24ea96a2fcfb8883c93007decc113038ebee2bc               -
data/incus/images/f5b430ec3ce7e741c3806c1d3e70eee842580ba892970084eefbe7861f3815e4               -
data/incus/images/f5b430ec3ce7e741c3806c1d3e70eee842580ba892970084eefbe7861f3815e4.block      128K
Ah yeah, that actually makes a lot of sense.
Because the instances are clones of the image, the blocksize will only apply on initial image unpack into ZFS.
So that makes it only really viable as a volume option on the pool, unless you have ZFS clones disabled on the pool (but then you’ll get much higher disk usage).
