I am tryig to migrate from ubuntu 14 to ubuntu 22 .
i have lxc2.0 running on ubuntu 14 and i could telnet to lxc container ips, however when i created a new contained on ubuntu 22 and tring to telnet it says permission denied
telnet> open 10.0.3.70
Trying 10.0.3.70…
telnet: Unable to connect to remote host: Connection refused
what is missing ?
Hi Tomp,
Thanks for reply.
Please find the output below … ip a
inet6 ::1/128 scope host
2: enp5s0f0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether a0:36:9f:44:4e:14 brd ff:ff:ff:ff:ff:ff
3: enp5s0f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether a0:36:9f:44:4e:15 brd ff:ff:ff:ff:ff:ff
4: enp5s0f2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether a0:36:9f:44:4e:16 brd ff:ff:ff:ff:ff:ff
5: enp5s0f3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether a0:36:9f:44:4e:17 brd ff:ff:ff:ff:ff:ff
6: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:30:48:a0:37:a2 brd ff:ff:ff:ff:ff:ff
altname enp8s0f0
inet 10.10.127.26/24 metric 100 brd 10.10.127.255 scope global dynamic eno1
valid_lft 748sec preferred_lft 748sec
inet6 fe80::230:48ff:fea0:37a2/64 scope link
32: wlp1s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether f8:16:54:46:bc:e8 brd ff:ff:ff:ff:ff:ff
33: wlp2s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether f8:16:54:37:11:da brd ff:ff:ff:ff:ff:ff
34: wlp3s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether f8:16:54:41:34:df brd ff:ff:ff:ff:ff:ff
35: wlp4s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether f4:7b:09:ca:d0:d2 brd ff:ff:ff:ff:ff:ff
37: lxcbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:00:00:00 brd ff:ff:ff:ff:ff:ff
inet 10.0.3.1/24 brd 10.0.3.255 scope global lxcbr0
inet6 fe80::216:3eff:fe00:0/64 scope link
40: veth6cbZXO@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxcbr0 state UP group default qlen 1000
link/ether fe:e4:24:90:42:d7 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::fce4:24ff:fe90:42d7/64 scope link
42: vethpreycG@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxcbr0 state UP group default qlen 1000
link/ether fe:4a:46:3b:67:4e brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet6 fe80::fc4a:46ff:fe3b:674e/64 scope link
valid_lft forever preferred_lft forever umtts@wifi6ts:~$ ip r
default via 10.10.127.1 dev eno1 proto dhcp src 10.10.127.26 metric 100
10.0.3.0/24 dev lxcbr0 proto kernel scope link src 10.0.3.1
10.10.1.220 via 10.10.127.1 dev eno1 proto dhcp src 10.10.127.26 metric 100
10.10.127.0/24 dev eno1 proto kernel scope link src 10.10.127.26 metric 100
10.10.127.1 dev eno1 proto dhcp scope link src 10.10.127.26 metric 100
10.10.127.221 dev eno1 proto dhcp scope link src 10.10.127.26 metric 100
10.20.1.220 via 10.10.127.1 dev eno1 proto dhcp src 10.10.127.26 metric 100 umtts@wifi6ts:~$ sudo iptables-save
[sudo] password for umtts:
Generated by iptables-save v1.8.7 on Tue May 3 23:59:05 2022
Hi Tomp,
Results From container:
ubuntu@dut1lan2:~$ ip a
2: eth0@if40: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:58:c9:78 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.0.3.176/24 metric 100 brd 10.0.3.255 scope global dynamic eth0
valid_lft 3567sec preferred_lft 3567sec
inet6 fe80::216:3eff:fe58:c978/64 scope link
ip r
default via 10.0.3.1 dev eth0 proto dhcp src 10.0.3.176 metric 100
10.0.3.0/24 dev eth0 proto kernel scope link src 10.0.3.176 metric 100
10.0.3.1 dev eth0 proto dhcp scope link src 10.0.3.176 metric 100
State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
LISTEN 0 4096 127.0.0.53%lo:53 0.0.0.0:*
LISTEN 0 128 0.0.0.0:22 0.0.0.0:*
LISTEN 0 128 [::]:22 [::]:*
I’m not familiar with running telnetd, have you checked your logs inside the container?
It seems like the port is open now, but the service is hanging.
Hi Tomp ,
Looks this file had an error “/etc/xinetd.conf” ;
i fix that by checking the status using
“sudo systemctl status inetd” and
restarted the service using
“sudo /etc/init.d/xinetd restart”
