I just was able to move a vm from one host to another.
Now, the networking does not seem to work. I cannot ping anything from inside the vm.
I have verified no iptables rules exist on the host (sudo iptables -F).
What steps should I use to check the network?
I see this when I review the networks, and things look fine at first glance.
$ incus network ls
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| docker0 | bridge | NO | | | | 0 | |
| enp5s0 | physical | NO | | | | 0 | |
| incus | bridge | YES | 10.191.241.1/24 | fd42:c30f:7a55:bbcb::1/64 | | 0 | CREATED |
| incus-network | bridge | YES | 10.9.193.1/24 | fd42:ab3e:6b6d:6686::1/64 | | 0 | CREATED |
| lo | loopback | NO | | | | 0 | |
| lxdbr0 | bridge | NO | | | | 0 | |
| virbr0 | bridge | NO | | | | 0 | |
| wlp4s0 | physical | NO | | | | 0 | |
xrdawson@homegpu:~$ incus info community-public-do-vm
Status: RUNNING
Type: virtual-machine
PID: 20153
Created: 2025/05/13 12:58 EDT
Last Used: 2025/05/13 13:12 EDT
Started: 2025/05/13 13:12 EDT
Operating System:
OS: Ubuntu
OS Version: 22.04.5 LTS (Jammy Jellyfish)
Kernel Version: 5.15.0-126-generic
Hostname: community-public-do-vm
FQDN: localhost
Resources:
Processes: 60
CPU usage:
CPU usage (in seconds): 51
Memory usage:
Memory (current): 2.63GiB
Network usage:
docker0:
Type: broadcast
State: UP
MAC address: 02:42:13:03:b6:97
MTU: 1500
Bytes received: 624B
Bytes sent: 1.54kB
Packets received: 12
Packets sent: 17
IP addresses:
inet: 172.17.0.1/16 (global)
inet6: fe80::42:13ff:fe03:b697/64 (link)
lo:
Type: loopback
State: UP
MTU: 65536
Bytes received: 190.70kB
Bytes sent: 190.70kB
Packets received: 2584
Packets sent: 2584
IP addresses:
inet: 127.0.0.1/8 (local)
inet6: ::1/128 (local)
tailscale0:
Type: point-to-point
State: UP
MTU: 1280
Bytes received: 86B
Bytes sent: 288B
Packets received: 1
Packets sent: 6
IP addresses:
inet6: fe80::efe8:2b95:f777:e9da/64 (link)
vetha50e085:
Type: broadcast
State: UP
MAC address: 36:95:db:a9:dd:57
MTU: 1500
Bytes received: 792B
Bytes sent: 2.48kB
Packets sent: 29
IP addresses:
inet6: fe80::3495:dbff:fea9:dd57/64 (link)
