I see, so the external IP traffic is already being routed to your LXC host?
In that case I would suggest using the router
NIC veth mode, which feels well suited to this, as it allows using external IPs inside a container without the need for a bridge.
See lxc.net.[i].type
in https://linuxcontainers.org/lxc/manpages//man5/lxc.container.conf.5.html
So, first, remove the bridge entirely.
Then use this in your container config:
lxc.net.0.type = veth
lxc.net.0.veth.mode = router
lxc.net.0.l2proxy = 1 # This enables proxy ARP/proxy NDP advertisement, not needed if IPs routed to host's LAN address already
lxc.net.0.link = eth1 # External interface (not the bridge)
lxc.net.0.flags = up
lxc.net.0.name = eth0
lxc.net.0.script.up = /usr/share/lxc/hooks/lxc-router-up
lxc.net.0.ipv4.gateway = 169.254.0.1 # This is a link-local next-hop address for IPv4
lxc.net.0.ipv6.gateway = fe80::1 # This is a link-local next-hop address for IPv6
lxc.net.0.ipv4.address = n.n.n.n.n/32 # Single IPv4 address
lxc.net.0.ipv6.address = .../128 # Single IPv6 address
Contents of /usr/share/lxc/hooks/lxc-router-up
#!/bin/sh
if [ -z "${LXC_NET_PEER}" ]
then
echo "LXC_NET_PEER not set"
exit 1
fi
sysctl net.ipv6.conf."${LXC_NET_PEER}".autoconf=0
sysctl net.ipv6.conf."${LXC_NET_PEER}".accept_dad=0
sysctl net.ipv6.conf."${LXC_NET_PEER}".accept_ra=0
sysctl net.ipv6.conf."${LXC_NET_PEER}".dad_transmits=0
sysctl net.ipv6.conf."${LXC_NET_PEER}".addr_gen_mode=1
ip a flush local dev "${LXC_NET_PEER}" scope link
ip a add fe80::1/64 dev "${LXC_NET_PEER}"
ip a add 169.254.0.1 dev "${LXC_NET_PEER}"
You’ll also need to ensure that the OS inside the container doesn’t remove the IPs configured by LXC, such as when triggering DHCP client request. And you’ll need to ensure DNS resolver IPs are configured manually.
