How to use cloud-init to set up a VM or container static IP
vm1 | RUNNING | 10.226.52.19 (enp5s0)
vm4 | RUNNING | 10.226.52.56 (enp5s0)
I want vm1 gateway set 10.226.52.56 dns 10.226.52.56 set up a route table in vm1 can be accessed after reboot The route table set will disappear
In your case, you’re looking at the network config data part (bottom of the page).
Here’s what i use, it’s the simplest way I’ve found to deploy preconfigured machines.
incus launch images:fedora/41/cloud myVM --vm \
  -c limits.cpu=2 \
  -c limits.memory=4GB \
  -d root,size=30GiB \
  -p default \
  -c cloud-init.network-config="$(cat <<EOF
version: 2
ethernets:
  enp5s0:
    addresses:
      - 192.168.1.0/24
    gateway4: 192.168.1.10
    nameservers:
      addresses:
        - 192.168.1.1
EOF
  -c cloud-init.user-data="$(cat <<EOF
#cloud-config
locale: en_US
timezone: UTC
hostname: myVM.example.com
package_update: true
package_upgrade: true
packages:
  - curl
  - vim
  - sudo
  - python3
  - python3-pip
  - ca-certificates
  - git
  - openssh-server
ca_certs:
  trusted:
    -----BEGIN CERTIFICATE-----
    CUSTOM_ROOT_CERTIFICATE_INSTALLATION
    -----END CERTIFICATE-----
users:
  - name: john
    gecos: John Smith
    primary_group: john
    groups: users, sudo
    sudo: ALL=(ALL) NOPASSWD:ALL
    ssh_authorized_keys:
      - ssh-ed25519 AAAAbbbbCCCCdddd john@example.com
  - name: ansible
    gecos: Ansible User
    primary_group: ansible
    groups: users, sudo
      - ssh-ed25519 AAAAbbbbCCCCdddd ansible@example.com
EOF
