I tried to use incus-simplestreams to make an images website from images that I create from containers.
When I publish a container into an image and then export the image, I get a single .tar.gz file containing rootfs/, metadata.yaml, and templates/.
incus-simplestreams seems to require a squashfs file with rootfs, and a tar.xz file with metadata.yaml and template/. So I had to extract rootfs from the .tar.gz file and convert it to a squashfs file, using mksquashfs. I also had to unpack metadata.yaml and templates/ from the .tar.gz file and repack them into a tar.xz file.
Is there a way to simplify this process? Can I publish/export the image from incus in the format required by incus-simplestreams?
Not so helpful maybe, but Image format - Incus documentation mentions two types of image formats (a unified tarball and split tarballs (what you seem to need)), but I can’t find any information how to tell the incus image export command to use a different format.
Using Distrobuilder is a whole different procedure than publishing images from containers. The images in images.linuxcontainers.org are probably all built using Distrobuilder.
Incus can import multiple image formats but simplestreams only supports the split format?
I’ve avoided sharing images via an incus server, because:
I don’t want to dedicate an incus host just for serving images
I don’t think it’s a good idea to use a production server with private instances to also serve public images. Even if it is technically feasible, I would worry about misconfiguring it.
I assume an incus server manages images of a single architecture, but I use both x86 and arm images.
I’ve been wanting to have my own simplestreams server for a long time. incus-simplestreams makes this feasible.
Aside: although incus publish --format split was added, it also looks like incus-simplestreams now supports publishing a unified image, in which case it’s not needed for this purpose.
$ incus-simplestreams add --help
If one argument is specified, it is assumed to be a unified image,
with both the metadata and rootfs in a single tarball.
Otherwise, it is a split image (separate files for metadata and rootfs/disk).
Usage:
incus-simplestreams add <metadata tarball> [<data file>] [flags]
Ah here:
commit 71c463f8b9981b1e8c8615387aa84d813be26059
Merge: d57a1ecac a3da639ef
Author: Stéphane Graber <stgraber@stgraber.org>
Date: Tue Jul 9 04:41:36 2024 +0200
Merge pull request #963 from melato/incus-simplestreams-add
incus-simplestreams add: can use unified or split image files
