How to use option of remote-viewer?
Greeting!
Can I use auto-resize with incus console?
Sometimes I need to use windows11,
so I typically type “incus console win11vm —type=vga.”
The opened window size is static.
To get more flexibility window, I found auto-resize option in remote-viewer.
Could you guide me on how to use auto-resize option with incus console command?
Yes, there are configuration options in place for this.
See CLI configuration file - Incus documentation
Thanks for sharing.
Good days all in all.^^*:sweat_smile:
