Howto: Build OCI images with podman and import into Incus
Took me a while to get that done.
I assume here you want to build a image where the resulting container is running caddy.
Versions in use:
OS: Debian trixie
incus: 6.19.1
podman: 5.4.2
Prepare incus metadata
Add docker.io as remote
incus remote add docker.io --protocol oci https://docker.io
Copy the image
incus image copy docker.io:caddy:2.11-alpine local: --alias caddy/2.11-alpine
Export the upstream image
incus image export caddy/2.11-alpine caddy-incus.tar
Extract Metadata
mkdir caddy-metadata
cd caddy-metadata
tar xf ../caddy-incus.tar
Add properties to metadata.yaml
Make it to look like this where "properties.type": "oci" is the important part
  "architecture":"x86_64",
  "creation_date":1766018662,
  "expiry_date":0,
  "properties": {
    "type": "oci",
    "description": "my caddy (OCI)",
  "templates":null
Create a tar out of the patched metadata
tar cf ../caddy-metadata.tar *
cd ..
Build the image with podman
podman build ./dir-with-a-dockerfile/ --output "type=tar,dest=caddy-rootfs.tar"
Import
incus image import caddy-metadata.tar caddy-rootfs.tar --alias my-caddy --reuse
Launch it
incus launch my-caddy my-cady
incus console --show-log my-caddy
Thanks for sharing.
As a follow up, I’m using something like this to redeploy a container:
incus rebuild -f local:my-caddy my-caddy
Now gonna find a minimal way to trigger that rebuild on git commits.
May I ask why you are not using Incus OCI support directly?
incus launch docker.io:caddy:2.11-alpine caddy
All fully supported by Incus and no need to deal with podman or anything else.
Ye, sure.
I build docker containers from a “Dockerfile” with podman and import the build without having to use a registry.
Hmm I could also setup a registry inside a incus container and use that one…
Done:
https://github.com/nuttyb-community/server
Added docs for anyone interested into the server repo.
