with static container IP
but when I connect to ftp I got errors
Server sent passive reply with unroutable address. Using server address instead
GnuTLS error -110: The TLS connection was non-properly terminated.
The data connection could not be established: ECONNABORTED - Connection aborted
You probably need to configure your FTP server’s config to use the lxd.host.ip as the passive response IP, as otherwise it’ll be using its own private IP.
