Hello, I have a small question as I’m trying to determine if something is normal, but I can’t seem to find information anywhere.
I’m on a Raspberry Pi 4, using the latest 64-bit version of Bookworm.
I have a container that I want to limit to using only one CPU and dedicate that CPU to the container. So I used the following commands:
sudo lxc config set App limits.cpu 0-0
sudo lxc config set App limits.cpu.allowance 100ms/100ms
Now, what I’m wondering is that when I’m observing the values in htop, everything seems fine; I can see that only one of my four cores is working.
But I also see some processes that go way beyond 100% utilization (some can go from 150% to 250%). Does this mean that it’s actually using more than one core, or is it attempting to use more than one? My searches on Google didn’t yield anything conclusive, but then again, maybe I didn’t use the right keywords.
Thanks in advance.
