I am not able to establish tcp connectivity from host towards the container, that resides on an ovn cluster
I am using the method recommended here:
What is the best approach access from host to ovn containers, with a route toward the ovn gateway address
I have a cluster setup with 3+1 nodes:
incus network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| UPLINK | physical | YES | | | | 1 | CREATED |
| br0 | bridge | NO | | | | 1 | |
| br-int | bridge | NO | | | | 0 | |
| ens3 | physical | NO | | | | 0 | |
| ens4 | physical | NO | | | | 0 | |
| ens5 | physical | NO | | | | 0 | |
| incusovn1 | bridge | NO | | | | 0 | |
| my-ovn | ovn | YES | 10.206.16.1/24 | fd42:dc1d:edde:fdb7::1/64 | | 2 | CREATED |
root@ubuntu:~# incus list
| c1 | RUNNING | 10.206.16.3 (eth0) | fd42:dc1d:edde:fdb7:216:3eff:fe2a:12ae (eth0) | CONTAINER | 0 | ubuntu01 |
| c11 | RUNNING | 10.206.16.2 (eth0) | fd42:dc1d:edde:fdb7:216:3eff:fe2d:d7e7 (eth0) | CONTAINER | 0 | ubuntu03 |
root@ubuntu:~# incus network show my-ovn
bridge.mtu: “1442”
ipv4.address: 10.206.16.1/24
ipv4.nat: “true”
ipv6.address: fd42:dc1d:edde:fdb7::1/64
ipv6.nat: “true”
network: UPLINK
volatile.network.ipv4.address: 10.255.239.140
description: “”
type: ovn
- /1.0/instances/c1
- /1.0/instances/c11
managed: true
status: Created
locations: - ubuntu02
- ubuntu03
- ubuntu04
- ubuntu01
10.206.16.2 via 10.255.239.140 dev br0 << routes toward ovn gateway
10.206.16.3 via 10.255.239.140 dev br0
I can ping the containers:
ping 10.206.16.2
PING 10.206.16.2 (10.206.16.2) 56(84) bytes of data.
64 bytes from 10.206.16.2: icmp_seq=1 ttl=63 time=5.65 ms
64 bytes from 10.206.16.2: icmp_seq=2 ttl=63 time=2.25 ms
but no tcp:
Connection reset by 10.206.16.2 port 22
tcpdump output on containers, show the R flag sent:
14:13:23.143516 eth0 In IP 10.255.239.181.47456 > 10.206.16.2.22: Flags [P.], seq 1:42, ack 1, win 502, options [nop,nop,TS val 3857057851 ecr 1692397751], length 41: SSH: SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.6
14:13:23.143567 eth0 Out IP 10.206.16.2.22 > 10.255.239.181.47456: Flags [.], ack 42, win 511, options [nop,nop,TS val 1692397757 ecr 3857057851], length 0
14:13:23.147105 eth0 In IP 10.255.239.181.47456 > 10.206.16.2.22: Flags [R], seq 4000848859, win 0, length 0
14:13:23.353320 eth0 In IP 10.255.239.181.47456 > 10.206.16.2.22: Flags [P.], seq 1:42, ack 1, win 502, options [nop,nop,TS val 3857058063 ecr 1692397751], length 41: SSH: SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.6
14:13:23.353348 eth0 Out IP 10.206.16.2.22 > 10.255.239.181.47456: Flags [R], seq 2610967809, win 0, length 0 <<<<
Seems like there is a firewall, but no firewall present on the container also no ACL was set.
Traffic between containers works normally
