These are both routed to the internet via our cloud provider. The IP .10 is already being used by the host system but is there a way to make my LXD Ubuntu container on the host system use only the .11 IP for all its traffic and not the .10 one?
I should map the IP automatically but it does not. I can set the IP inside the container but that does not stay after a container restart. Also I got no connectivity even when I set the ip.
If you don’t have any services using the 10.0.0.11 address on your LXD host currently, then removing it from the host and moving it into the container using the routed NIC type will allow it to be entirely used by the container for ingress and egress traffic.
