(IBus) Can not type Vietnamese on gui applications in container
Hello guys,
I installed the application according to the instructions https://blog.simos.info/how-to-easily-run-graphics-accelerated-gui-apps-in-lxd-containers-on-your-ubuntu-desktop/. I also installed ibus-unikey in the gui container. The application works normally but I have problems with the input method, namely ibus-unikey, I cannot type Vietnamese on some applications such as chrome, viber, signal, etc. although I can type Vietnamese on firefox, gedit.
I need your help and sincerely thank you for any feedback!
I’m stuck on this problem too. is there any progress?
Hi!
Can you try to set the following variables first.
export GTK_IM_MODULE=ibus
export XMODIFIERS=@im=ibus
export QT_IM_MODULE=ibus
and then run those applications to test whether they work now?
Thanks for your help but they not work. I think I should give it up.
I am not familiar with ibus input methods.
If you can give simple instructions on how to set this up on a desktop computer, I can give it a go.
Hi, all, I find the solution (maybe). I use fcitx in my ubuntu 18.04 container, and it’s working. You may have a try with ibus.
TL;DR:
  1. You must set locale in container the same as your host, MUST NOT use C/C.UTF-8/POSIX in container, otherwise the input method window will not show. For my environment, it’s LANG=zh_CN.UTF-8
  2. You must set the XMODIFIERS environment variable in container the same as your host. For my environment, it’s XMODIFIERS='@im=fcitx'
  3. The correct raw.idmap config for container, see: https://blog.simos.info/how-to-easily-run-graphics-accelerated-gui-apps-in-lxd-containers-on-your-ubuntu-desktop/. For example, your current user in host uid is 1000, and you want use non root user in container, which uid is also 1000, you should set: raw.idmap: both 1000 1000.
Full steps:
My instance is Ubuntu 18.04, and I use fcitx input method, maybe you can compare with ibus.
Here is my gui profile:
lxc show profile gui
# These environment variables only work for lxc exec.
# If you are not using lxc exec to access container
# you should set these environment vaiables manually
  environment.DISPLAY: :0
  environment.PULSE_SERVER: unix:/tmp/.pulse-native
  environment.XMODIFIERS: '@im=fcitx'
  raw.idmap: both 1000 1000     # <=== Must fit for your environment
description: GUI LXD profile
  X0:
    path: /tmp/.X11-unix/
    source: /tmp/.X11-unix/
  mygpu:
    mode: "0666"
    type: gpu
  pulseaudio:
    path: /tmp/.pulse-native
    source: /run/user/1000/pulse/native
Lanuch ubuntu bionic image from ubuntu-daily repo:
$ lxc launch ubuntu-daily:bionic ubuntu-bionic-testing -p default -p gui
Creating ubuntu-bionic-testing
Starting ubuntu-bionic-testing
I use non root user in the container, and Ubuntu official lxd image providers a ubuntu user by default. Other image maybe you should create a user by yourself.
# su will not pass root env, you should set the XMODIFIERS manually
$ lxc exec ubuntu-bionic-testing su - ubuntu
ubuntu@ubuntu-bionic-testing:~$ env
LANG=C.UTF-8   # <=== should change locale as same as host
DISPLAY=:0
# you can set to ~/.bashrc for permanent, you must keep XMODIFIERS variable as same as host
$ export XMODIFIERS=@im=fcitx
$ echo $XMODIFIERS
@im=fcitx
# Change locale to zh_CN.UTF-8, for other os you may use locale-gen manually
$ sudo apt update && sudo apt install -y language-pack-zh-hans
$ locale -a
C
C.UTF-8
POSIX
en_US.utf8
zh_CN.utf8   #<==== After install language-pack-zh-hans you can see this local
zh_SG.utf8
$ sudo localectl set-locale LANG=zh_CN.UTF-8
$ localectl
   System Locale: LANG=zh_CN.UTF-8        #<=== It's working
       VC Keymap: n/a
      X11 Layout: us
       X11 Model: pc105
$ locale  # current locale is still C.UTF-8, you must logout and login again
LANG=C.UTF-8
LANGUAGE=
LC_CTYPE="C.UTF-8"
LC_NUMERIC="C.UTF-8"
LC_TIME="C.UTF-8"
LC_COLLATE="C.UTF-8"
LC_MONETARY="C.UTF-8"
LC_MESSAGES="C.UTF-8"
LC_PAPER="C.UTF-8"
LC_NAME="C.UTF-8"
LC_ADDRESS="C.UTF-8"
LC_TELEPHONE="C.UTF-8"
LC_MEASUREMENT="C.UTF-8"
LC_IDENTIFICATION="C.UTF-8"
LC_ALL=
# After login again:
$ locale
LANG=zh_CN.UTF-8
LANGUAGE=
LC_CTYPE="zh_CN.UTF-8"
LC_NUMERIC="zh_CN.UTF-8"
LC_TIME="zh_CN.UTF-8"
LC_COLLATE="zh_CN.UTF-8"
LC_MONETARY="zh_CN.UTF-8"
LC_MESSAGES="zh_CN.UTF-8"
LC_PAPER="zh_CN.UTF-8"
LC_NAME="zh_CN.UTF-8"
LC_ADDRESS="zh_CN.UTF-8"
LC_TELEPHONE="zh_CN.UTF-8"
LC_MEASUREMENT="zh_CN.UTF-8"
LC_IDENTIFICATION="zh_CN.UTF-8"
LC_ALL=
Finally, install the fonts as you need, otherwise your font will not display on the graph. For example, I need the CJK fonts:
$ sudo apt install -y fonts-noto-cjk
Then you can use gtk-demo for testing:
$ sudo apt install -y gtk2.0-examples
$ gtk-demo
Note that you must install the fonts first, otherwise the font will not display.
And also, firefox and chromium should work too.
I hope this can help you. :grinning: :grinning: :grinning:
And I try with ArchLinux in images repo, still working. :face_with_hand_over_mouth: :face_with_hand_over_mouth: :face_with_hand_over_mouth:
lxc launch images:archlinux arch -p default -p gui
But I have to umount /tmp in container first, I don’t know why the archlinux container mount /tmp after all, which overrides my mount point /tmp/.X11-unix/ and /tmp/.pulse-native.
