Tutorial: Ibus Setup in a GUI-enabled Incus Container
“IBus (Intelligent Input Bus) is an input method framework, a type of application that allows for easily switching between different keyboard layouts.”
In this tutorial, we will learn:
How to set up ibus in a GUI-enabled incus container
How to add a ibus input method
How to autostart ibus daemon
In this tutorial, we will set up two input methods as an example:
English (UK)
Chinese - Pinyin
Set up a GUI-enabled Incus Container
This tutorial assume we work with a container named ‘ub’ that supports GUI applications. you may change the container name ‘ub’ to your own ones.
To set up a GUI-enabled Incus Container, read one of the following examples:
Running GUI Apps via Incus on Ubuntu 22.04 LTS
Running GUI Apps via Incus on Ubuntu 24.04 LTS
Manage language packages
English package is installed by default.
In this example, we will add a Chinese package
Edit /etc/locale.gen:
sudo nano /etc/locale.gen
Locate and uncomment “zh_CN.UTF8 UTF8”
To download the newly selected language package(s), run:
sudo locale-gen
Add Chinese fonts
sudo apt install -y xfonts-wqy ttf-wqy-zenhei ttf-wqy-microhei fonts-arphic-bkai00mp fonts-arphic-bsmi00lp fonts-arphic-gbsn00lp fonts-arphic-gkai00mp xfonts-intl-chinese xfonts-intl-chinese-big
Add input method
Example - add ibus-pinyin
sudo apt install ibus-pinyin
ibus restart
ibus-setup
Go to tab “Input Method”:
Select “Add” > “English” > “English (UK)” > “Add”
Select “Add” > “Chinese” > “Pinyin” > “Add”
Select “Close”
Configure ibus as default input:
This step is important! Don’t miss it.
sudo apt install im-config
im-config
Select options according to the following order as you walk through the im-config dialog:
select "OK"
select "Yes"
select "ibus"
select "OK"
Add environment variables
nano ~/.bashrc
export LC_CTYPE=zh_CN.UTF-8
export XIM=ibus
export XIM_PROGRAM=/usr/bin/ibus
export QT_IM_MODULE=ibus
export GTK_IM_MODULE=ibus
export XMODIFIERS=@im=ibus
export DefaultIMModule=ibus
source ~/.bashrc
Auto-start Ibus Daemon
Append the ~/.profile file to auto-start ibus daemon:
echo “ibus-daemon -drx” >> ~/.profile
sudo reboot
Now, when you login this container again, you can see the ibus interface will be seamlessly loaded on the “Top Panel” or “Header Bar”, where you can change the ibus input methods for your container GUI applications.
