when I create a new container, all files in that container use the exact same UIDs and GIDs as the host, even when I enable idmap isolation:
# incus storage list
| default | dir | /var/lib/incus/storage-pools/default | | 10 | CREATED |
# cat /etc/subuid
incus:65536:1000000000
root:65536:1000000000
# cat /etc/subgid
# incus init images:debian/12 test-new
Creating test-new
Retrieving image: Unpack: 100% (1.12GB/s)
# incus config set test-new security.idmap.isolated=true
# incus start test-new
# incus exec test-new bash
root@test-new:~# touch foo
root@test-new:~# ls -l foo
-rw-r--r-- 1 root root 0 Jun 11 22:16 foo
root@test-new:~#
exit
# ls -l /var/lib/incus/storage-pools/default/containers/test-new/rootfs/root/
total 0
# incus config show test-new
image.architecture: amd64
image.description: Debian bookworm amd64 (20240611_05:24)
image.os: Debian
image.release: bookworm
image.serial: "20240611_05:24"
image.type: squashfs
image.variant: default
security.idmap.isolated: "true"
volatile.base_image: d02788aeece968be5715583bc59c3d2931d69010b68dbdce531924d1721febe8
volatile.cloud-init.instance-id: 6f4cf812-d741-4f53-87a5-98ab20328b8b
volatile.eth0.host_name: vethca4089a2
volatile.eth0.hwaddr: 00:16:3e:f1:bc:a7
volatile.idmap.base: "262144"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":262144,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":262144,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":262144,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":262144,"Nsid":0,"Maprange":65536}]'
volatile.uuid: 4a7357d0-d9b0-45c6-a7b7-216bbf6546ce
volatile.uuid.generation: 4a7357d0-d9b0-45c6-a7b7-216bbf6546ce
devices: {}
As you can see, the file foo
belongs to root
in the container, but also in the host filesystem.
Even stranger: for already existing containers, everything works as expected:
# incus exec nas bash
root@nas:~# touch foo
root@nas:~# ls -l foo
-rw-r--r-- 1 root root 0 Jun 12 07:31 foo
root@nas:~#
exit
# ls -l /var/lib/incus/storage-pools/default/containers/nas/rootfs/root/foo
-rw-r--r-- 1 131072 131072 0 Jun 12 09:31 /var/lib/incus/storage-pools/default/containers/nas/rootfs/root/foo
Here, the file foo
doesn’t belong to root
on the host fs, as expected.
This behaviour started on LXD after upgrading from Debian 11 to 12 and is still present now on Incus.
What am I doing wrong?
