Hi all
I need some help to understand potential issue I face.
I have a new server and I made a fresh install of Debian Trixie and incus with the Zabbly repo.
After the installation, I create my first container based on the Debian trixie and i see that the rootfs and all file created with the host root uid/sid
sudo ls -al /var/lib/incus/containers/test/
total 8
d--x------ 1 root root 78 17 janv. 19:37 .
drwx--x--x 1 root root 70 17 janv. 19:37 ..
-r-------- 1 root root 3547 17 janv. 19:37 backup.yaml
-rw-r--r-- 1 root root 529 17 janv. 06:31 metadata.yaml
drwxr-xr-x 1 root root 132 17 janv. 06:31 rootfs
drwxr-xr-x 1 root root 42 17 janv. 06:31 templates
sudo ls -al /var/lib/incus/containers/test/rootfs/
total 16
drwxr-xr-x 1 root root 132 17 janv. 06:31 .
d--x------ 1 root root 78 17 janv. 19:37 ..
lrwxrwxrwx 1 root root 7 2 janv. 13:35 bin -> usr/bin
drwxr-xr-x 1 root root 0 2 janv. 13:35 boot
drwxr-xr-x 1 root root 0 17 janv. 06:31 dev
drwxr-xr-x 1 root root 1584 17 janv. 06:31 etc
drwxr-xr-x 1 root root 0 2 janv. 13:35 home
lrwxrwxrwx 1 root root 7 2 janv. 13:35 lib -> usr/lib
lrwxrwxrwx 1 root root 9 2 janv. 13:35 lib64 -> usr/lib64
drwxr-xr-x 1 root root 0 17 janv. 06:24 media
drwxr-xr-x 1 root root 0 17 janv. 06:24 mnt
drwxr-xr-x 1 root root 0 17 janv. 06:24 opt
drwxr-xr-x 1 root root 0 2 janv. 13:35 proc
drwx------ 1 root root 38 17 janv. 06:25 root
drwxr-xr-x 1 root root 0 17 janv. 06:26 run
lrwxrwxrwx 1 root root 8 2 janv. 13:35 sbin -> usr/sbin
drwxr-xr-x 1 root root 0 17 janv. 06:24 srv
drwxr-xr-x 1 root root 0 2 janv. 13:35 sys
drwxrwxrwt 1 root root 0 17 janv. 06:25 tmp
drwxr-xr-x 1 root root 94 17 janv. 06:24 usr
drwxr-xr-x 1 root root 90 17 janv. 06:24 var
I checked my file subuid and subguid without see any issue
cat /etc/subuid
manchot:100000:65536
manchotadm:165536:65536
root:1000000:1000000000
root:1001:1
cat /etc/subgid
root:1001:1
Container config if it’s necessary
incus config show test
image.architecture: amd64
image.description: Debian trixie amd64 (20260117_05:24)
image.os: Debian
image.release: trixie
image.serial: "20260117_05:24"
image.type: squashfs
image.variant: default
volatile.apply_template: create
volatile.base_image: 41506f0145c43eb8f741f0249be54f193d204fd6e1e4b1b412825650eea6bfc8
volatile.cloud-init.instance-id: 9b48418e-2f5b-4f7e-9a00-9600ae6b70a4
volatile.enp1s0.hwaddr: 10:66:6a:4e:d7:f6
volatile.enp1s0.name: eth0
volatile.idmap.base: "0"
volatile.uuid: 98a93fcd-523e-451f-82fd-8b033af17a0e
volatile.uuid.generation: 98a93fcd-523e-451f-82fd-8b033af17a0e
devices: {}
- base
Base profile
incus profile show base
boot.autostart: "true"
limits.memory: 500MB
limits.memory.enforce: soft
limits.memory.swap: "true"
limits.memory.swap.priority: "6"
security.nesting: "true"
snapshots.expiry: 1w
snapshots.pattern: backup-%d
snapshots.schedule: '@daily'
snapshots.schedule.stopped: "false"
description: Base template profile
enp1s0:
nictype: bridged
parent: brincus0
pool: containers
- /1.0/instances/test
project: default
Could you please help me to understand the issue and how to correct it because for me normally the rootfs folder need to have uid:gid 1000000 for the unpriviledge container with this configuration…
Thank you
