lxc.pty.max
As far as I can tell, all (standard, like when you pop open a new window, and also the ones any given script which forked/running on its own and not in an actual tty interfaces with) pttys in linux ultimately talk to one singular instance of a “Server Emulator” on the other end of their respective virtual “Teletype Connections.” Using this option starts a new “Server Emulator” private to the container? Is that right? And the (not-yet-working) value is the maximum number of terminal emulators it allows? Or all virtual TTY links, including between forking and forked processes? Or the maximum number of PTTYs using linux commands and connecting to the “Server emulator” at once, including scripts?
lxc.tty.max
This is the number of sandboxed host ptty instances (do these get replaced with connections to the guest “TTY Server Emulator” instance, if lxc.pty.max is set?) LXC sends to the client to potentially use as its own ttys? Is that right? So this should ideally be set to, in Ubuntu for example, 8, becuase that’s how many standard ttys exist in a typical Ubuntu client?
lxc.tty.dir
Where the sandboxed host ptty instances LXC sends to the client to potentially use as its own ttys live on the client. This one I think I get, but how does can it block guest upgrades in its normal, default locations? Is it a refusal to allow the client package updater to write to them (or their backend infrastructure somewhere?) If so, how do the symlinks they recommend avoid getting overwritten with non-emulated ones by the package upgrader and thereby fucked up?
Thanks in advance for all the help, guys! I appreciate your patience in dealing w/ clusless noobs like yours truly.
