I’ll try to import containers on a zfs pool connected to a boot disk,containing Ubuntu Server, but probably missing something obviously. Tried to look up similar cases already.
Im running Ubuntu 20.04
root@freenas:/var/snap/lxd/common/lxd/images# sudo lxd import Plex
Error: The instance's directory "/var/snap/lxd/common/lxd/storage-pools/default/containers/Plex" appears to be empty. Please ensure that the instance's storage volume is mounted
Mount point is not empty:
root@freenas:/var/snap/lxd/common/lxd/images# ls -l /var/snap/lxd/common/lxd/storage-pools/default/containers/Plex/
total 9
-r-------- 1 root root 2260 Jun 10 17:26 backup.yaml
-rw-r--r-- 1 root root 1049 May 30 01:16 metadata.yaml
drwxr-xr-x 18 root root 24 Jun 10 17:26 rootfs
drwxr-xr-x 2 root root 7 May 30 01:16 templates
the mount point
root@freenas:/var/snap/lxd/common/lxd/images# zfs list
mydata 641G 13.4T 631G /mydata
mydata/LXD 10.2G 13.4T 24K none
mydata/LXD/containers 7.65G 13.4T 24K none
mydata/LXD/containers/OsSec 518M 13.4T 1.33G /var/snap/lxd/common/lxd/storage-pools/default/containers/OsSec
mydata/LXD/containers/Plex 6.97G 13.4T 7.79G /var/snap/lxd/common/lxd/storage-pools/default/containers/Plex
mydata/LXD/containers/Tor 170M 13.4T 584M /var/snap/lxd/common/lxd/storage-pools/default/containers/Tor
mydata/LXD/custom 24K 13.4T 24K none
mydata/LXD/deleted 1.26G 13.4T 24K none
mydata/LXD/deleted/containers 24K 13.4T 24K none
cat /var/snap/lxd/common/lxd/storage-pools/default/containers/Plex/backup.yaml
container:
boot.autostart: "true"
image.architecture: amd64
image.description: ubuntu 20.04 LTS amd64 (release) (20200529.1)
image.label: release
image.os: ubuntu
image.release: focal
image.serial: "20200529.1"
image.type: squashfs
image.version: "20.04"
raw.apparmor: mount fstype=nfs,
security.privileged: "true"
volatile.base_image: 42424696bc6fc56ebff11508b597946b8f451f002a780bf0a943051130712a8f
volatile.eth0.host_name: veth84846129
volatile.eth0.hwaddr: 4e:08:39:2f:0f:d0
volatile.eth0.name: eth0
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
devices: {}
- lanprofile
created_at: 2020-06-04T18:25:56.744383356+02:00
expanded_config:
image.os: ubuntu
expanded_devices:
nictype: bridged
parent: br0
pool: default
status: Stopped
status_code: 102
last_used_at: 2020-06-10T07:01:04.937544907+02:00
type: container
snapshots: []
pool:
source: mydata/LXD
volatile.initial_source: mydata/LXD
zfs.pool_name: mydata/LXD
driver: zfs
used_by: []
status: Created
locations:
- none
volume:
config: {}
type: container
used_by: []
Can someone help me out?
This is a priviledged container
Geert
