Import lxd containers fails with EOF error
Hi there!
I am currently struggling to migrate to incus.
At this point i do not really see how I can proberly import my lxd containers:
I did in lxd:
Export all my lcd containers:
for i in $(lxc list -c n --format csv); do echo "Backing up ${i}..."; lxc export "${i}" "/media/backup
/containers/${i}-backup-$(date +%Y-%m-%d).tar.xz"; done
The backup was successful.
Then i tried to import them with:
benjamin@librem-mini:~$ sudo incus --debug import /media/backup/containers/proxy-backup-2026-03-05.tar.xz
DEBUG  [2026-03-06T11:39:40+01:00] Connecting to a local Incus over a Unix socket
DEBUG  [2026-03-06T11:39:40+01:00] Sending request to Incus                      etag= method=GET url="http://unix.socket/1.0"
DEBUG  [2026-03-06T11:39:40+01:00] Got response struct from Incus
                "config": {},
                "api_extensions": [
                        "storage_zfs_remove_snapshots",
                        "container_host_shutdown_timeout",
                        "container_stop_priority",
                        "container_syscall_filtering",
                        "auth_pki",
                        "container_last_used_at",
                        "etag",
                        "patch",
                        "usb_devices",
                        "https_allowed_credentials",
                        "image_compression_algorithm",
                        "directory_manipulation",
                        "container_cpu_time",
                        "storage_zfs_use_refquota",
                        "storage_lvm_mount_options",
                        "network",
                        "profile_usedby",
                        "container_push",
                        "container_exec_recording",
                        "certificate_update",
                        "container_exec_signal_handling",
                        "gpu_devices",
                        "container_image_properties",
                        "migration_progress",
                        "id_map",
                        "network_firewall_filtering",
                        "network_routes",
                        "storage",
                        "file_delete",
                        "file_append",
                        "network_dhcp_expiry",
                        "storage_lvm_vg_rename",
                        "storage_lvm_thinpool_rename",
                        "network_vlan",
                        "image_create_aliases",
                        "container_stateless_copy",
                        "container_only_migration",
                        "storage_zfs_clone_copy",
                        "unix_device_rename",
                        "storage_lvm_use_thinpool",
                        "storage_rsync_bwlimit",
                        "network_vxlan_interface",
                        "storage_btrfs_mount_options",
                        "entity_description",
                        "image_force_refresh",
                        "storage_lvm_lv_resizing",
                        "id_map_base",
                        "file_symlinks",
                        "container_push_target",
                        "network_vlan_physical",
                        "storage_images_delete",
                        "container_edit_metadata",
                        "container_snapshot_stateful_migration",
                        "storage_driver_ceph",
                        "storage_ceph_user_name",
                        "resource_limits",
                        "storage_volatile_initial_source",
                        "storage_ceph_force_osd_reuse",
                        "storage_block_filesystem_btrfs",
                        "resources",
                        "kernel_limits",
                        "storage_api_volume_rename",
                        "network_sriov",
                        "console",
                        "restrict_dev_incus",
                        "migration_pre_copy",
                        "infiniband",
                        "dev_incus_events",
                        "proxy",
                        "network_dhcp_gateway",
                        "file_get_symlink",
                        "network_leases",
                        "unix_device_hotplug",
                        "storage_api_local_volume_handling",
                        "operation_description",
                        "clustering",
                        "event_lifecycle",
                        "storage_api_remote_volume_handling",
                        "nvidia_runtime",
                        "container_mount_propagation",
                        "container_backup",
                        "dev_incus_images",
                        "container_local_cross_pool_handling",
                        "proxy_unix",
                        "proxy_udp",
                        "clustering_join",
                        "proxy_tcp_udp_multi_port_handling",
                        "network_state",
                        "proxy_unix_dac_properties",
                        "container_protection_delete",
                        "unix_priv_drop",
                        "pprof_http",
                        "proxy_haproxy_protocol",
                        "network_hwaddr",
                        "proxy_nat",
                        "network_nat_order",
                        "container_full",
                        "backup_compression",
                        "nvidia_runtime_config",
                        "storage_api_volume_snapshots",
                        "storage_unmapped",
                        "projects",
                        "network_vxlan_ttl",
                        "container_incremental_copy",
                        "usb_optional_vendorid",
                        "snapshot_scheduling",
                        "snapshot_schedule_aliases",
                        "container_copy_project",
                        "clustering_server_address",
                        "clustering_image_replication",
                        "container_protection_shift",
                        "snapshot_expiry",
                        "container_backup_override_pool",
                        "snapshot_expiry_creation",
                        "network_leases_location",
                        "resources_cpu_socket",
                        "resources_gpu",
                        "resources_numa",
                        "kernel_features",
                        "id_map_current",
                        "event_location",
                        "storage_api_remote_volume_snapshots",
                        "network_nat_address",
                        "container_nic_routes",
                        "cluster_internal_copy",
                        "seccomp_notify",
                        "lxc_features",
                        "container_nic_ipvlan",
                        "network_vlan_sriov",
                        "storage_cephfs",
                        "container_nic_ipfilter",
                        "resources_v2",
                        "container_exec_user_group_cwd",
                        "container_syscall_intercept",
                        "container_disk_shift",
                        "storage_shifted",
                        "resources_infiniband",
                        "daemon_storage",
                        "instances",
                        "image_types",
                        "resources_disk_sata",
                        "clustering_roles",
                        "images_expiry",
                        "resources_network_firmware",
                        "backup_compression_algorithm",
                        "ceph_data_pool_name",
                        "container_syscall_intercept_mount",
                        "compression_squashfs",
                        "container_raw_mount",
                        "container_nic_routed",
                        "container_syscall_intercept_mount_fuse",
                        "container_disk_ceph",
                        "virtual-machines",
                        "image_profiles",
                        "clustering_architecture",
                        "resources_disk_id",
                        "storage_lvm_stripes",
                        "vm_boot_priority",
                        "unix_hotplug_devices",
                        "api_filtering",
                        "instance_nic_network",
                        "clustering_sizing",
                        "firewall_driver",
                        "projects_limits",
                        "container_syscall_intercept_hugetlbfs",
                        "limits_hugepages",
                        "container_nic_routed_gateway",
                        "projects_restrictions",
                        "custom_volume_snapshot_expiry",
                        "volume_snapshot_scheduling",
                        "trust_ca_certificates",
                        "snapshot_disk_usage",
                        "clustering_edit_roles",
                        "container_nic_routed_host_address",
                        "container_nic_ipvlan_gateway",
                        "resources_usb_pci",
                        "resources_cpu_threads_numa",
                        "resources_cpu_core_die",
                        "api_os",
                        "container_nic_routed_host_table",
                        "container_nic_ipvlan_host_table",
                        "container_nic_ipvlan_mode",
                        "resources_system",
                        "images_push_relay",
                        "network_dns_search",
                        "container_nic_routed_limits",
                        "instance_nic_bridged_vlan",
                        "network_state_bond_bridge",
                        "usedby_consistency",
                        "custom_block_volumes",
                        "clustering_failure_domains",
                        "resources_gpu_mdev",
                        "console_vga_type",
                        "projects_limits_disk",
                        "network_type_macvlan",
                        "network_type_sriov",
                        "container_syscall_intercept_bpf_devices",
                        "network_type_ovn",
                        "projects_networks",
                        "projects_networks_restricted_uplinks",
                        "custom_volume_backup",
                        "backup_override_name",
                        "storage_rsync_compression",
                        "network_type_physical",
                        "network_ovn_external_subnets",
                        "network_ovn_nat",
                        "network_ovn_external_routes_remove",
                        "tpm_device_type",
                        "storage_zfs_clone_copy_rebase",
                        "gpu_mdev",
                        "resources_pci_iommu",
                        "resources_network_usb",
                        "resources_disk_address",
                        "network_physical_ovn_ingress_mode",
                        "network_ovn_dhcp",
                        "network_physical_routes_anycast",
                        "projects_limits_instances",
                        "network_state_vlan",
                        "instance_nic_bridged_port_isolation",
                        "instance_bulk_state_change",
                        "network_gvrp",
                        "instance_pool_move",
                        "gpu_sriov",
                        "pci_device_type",
                        "storage_volume_state",
                        "network_acl",
                        "migration_stateful",
                        "disk_state_quota",
                        "storage_ceph_features",
                        "projects_compression",
                        "projects_images_remote_cache_expiry",
                        "certificate_project",
                        "network_ovn_acl",
                        "projects_images_auto_update",
                        "projects_restricted_cluster_target",
                        "images_default_architecture",
                        "network_ovn_acl_defaults",
                        "gpu_mig",
                        "project_usage",
                        "network_bridge_acl",
                        "warnings",
                        "projects_restricted_backups_and_snapshots",
                        "clustering_join_token",
                        "clustering_description",
                        "server_trusted_proxy",
                        "clustering_update_cert",
                        "storage_api_project",
                        "server_instance_driver_operational",
                        "server_supported_storage_drivers",
                        "event_lifecycle_requestor_address",
                        "resources_gpu_usb",
                        "clustering_evacuation",
                        "network_ovn_nat_address",
                        "network_bgp",
                        "network_forward",
                        "custom_volume_refresh",
                        "network_counters_errors_dropped",
                        "metrics",
                        "image_source_project",
                        "clustering_config",
                        "network_peer",
                        "linux_sysctl",
                        "network_dns",
                        "ovn_nic_acceleration",
                        "certificate_self_renewal",
                        "instance_project_move",
                        "storage_volume_project_move",
                        "cloud_init",
                        "network_dns_nat",
                        "database_leader",
                        "instance_all_projects",
                        "clustering_groups",
                        "ceph_rbd_du",
                        "instance_get_full",
                        "qemu_metrics",
                        "gpu_mig_uuid",
                        "event_project",
                        "clustering_evacuation_live",
                        "instance_allow_inconsistent_copy",
                        "network_state_ovn",
                        "storage_volume_api_filtering",
                        "image_restrictions",
                        "storage_zfs_export",
                        "network_dns_records",
                        "storage_zfs_reserve_space",
                        "network_acl_log",
                        "storage_zfs_blocksize",
                        "metrics_cpu_seconds",
                        "instance_snapshot_never",
                        "certificate_token",
                        "instance_nic_routed_neighbor_probe",
                        "event_hub",
                        "agent_nic_config",
                        "projects_restricted_intercept",
                        "metrics_authentication",
                        "images_target_project",
                        "images_all_projects",
                        "cluster_migration_inconsistent_copy",
                        "cluster_ovn_chassis",
                        "container_syscall_intercept_sched_setscheduler",
                        "storage_lvm_thinpool_metadata_size",
                        "storage_volume_state_total",
                        "instance_file_head",
                        "instances_nic_host_name",
                        "image_copy_profile",
                        "container_syscall_intercept_sysinfo",
                        "clustering_evacuation_mode",
                        "resources_pci_vpd",
                        "qemu_raw_conf",
                        "storage_cephfs_fscache",
                        "network_load_balancer",
                        "vsock_api",
                        "instance_ready_state",
                        "network_bgp_holdtime",
                        "storage_volumes_all_projects",
                        "metrics_memory_oom_total",
                        "storage_buckets",
                        "storage_buckets_create_credentials",
                        "metrics_cpu_effective_total",
                        "projects_networks_restricted_access",
                        "storage_buckets_local",
                        "loki",
                        "acme",
                        "internal_metrics",
                        "cluster_join_token_expiry",
                        "remote_token_expiry",
                        "init_preseed",
                        "storage_volumes_created_at",
                        "cpu_hotplug",
                        "projects_networks_zones",
                        "network_txqueuelen",
                        "cluster_member_state",
                        "instances_placement_scriptlet",
                        "storage_pool_source_wipe",
                        "zfs_block_mode",
                        "instance_generation_id",
                        "disk_io_cache",
                        "amd_sev",
                        "storage_pool_loop_resize",
                        "migration_vm_live",
                        "ovn_nic_nesting",
                        "oidc",
                        "network_ovn_l3only",
                        "ovn_nic_acceleration_vdpa",
                        "cluster_healing",
                        "instances_state_total",
                        "auth_user",
                        "security_csm",
                        "instances_rebuild",
                        "numa_cpu_placement",
                        "custom_volume_iso",
                        "network_allocations",
                        "zfs_delegate",
                        "storage_api_remote_volume_snapshot_copy",
                        "operations_get_query_all_projects",
                        "metadata_configuration",
                        "syslog_socket",
                        "event_lifecycle_name_and_project",
                        "instances_nic_limits_priority",
                        "disk_initial_volume_configuration",
                        "operation_wait",
                        "image_restriction_privileged",
                        "cluster_internal_custom_volume_copy",
                        "disk_io_bus",
                        "storage_cephfs_create_missing",
                        "instance_move_config",
                        "ovn_ssl_config",
                        "certificate_description",
                        "disk_io_bus_virtio_blk",
                        "loki_config_instance",
                        "instance_create_start",
                        "clustering_evacuation_stop_options",
                        "boot_host_shutdown_action",
                        "agent_config_drive",
                        "network_state_ovn_lr",
                        "image_template_permissions",
                        "storage_bucket_backup",
                        "storage_lvm_cluster",
                        "shared_custom_block_volumes",
                        "auth_tls_jwt",
                        "oidc_claim",
                        "device_usb_serial",
                        "numa_cpu_balanced",
                        "image_restriction_nesting",
                        "network_integrations",
                        "instance_memory_swap_bytes",
                        "network_bridge_external_create"
                "api_status": "stable",
                "api_version": "1.0",
                "auth": "trusted",
                "public": false,
                "auth_methods": [
                        "tls"
                "auth_user_name": "root",
                "auth_user_method": "unix",
                "environment": {
                        "addresses": [],
                        "architectures": [
                                "x86_64",
                                "i686"
                        "certificate": "-----BEGIN CERTIFICATE-----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\nQTM=\n-----END CERTIFICATE-----\n",
                        "certificate_fingerprint": "74af5c099a113440289e9d47a6315bd4d5cec68097362fd5c0ded12029175170",
                        "driver": "lxc",
                        "driver_version": "5.0.3",
                        "firewall": "nftables",
                        "kernel": "Linux",
                        "kernel_architecture": "x86_64",
                        "kernel_features": {
                                "idmapped_mounts": "true",
                                "netnsid_getifaddrs": "true",
                                "seccomp_listener": "true",
                                "seccomp_listener_continue": "true",
                                "uevent_injection": "true",
                                "unpriv_binfmt": "true",
                                "unpriv_fscaps": "true"
                        "kernel_version": "6.8.0-101-generic",
                        "lxc_features": {
                                "cgroup2": "true",
                                "core_scheduling": "true",
                                "devpts_fd": "true",
                                "idmapped_mounts_v2": "true",
                                "mount_injection_file": "true",
                                "network_gateway_device_route": "true",
                                "network_ipvlan": "true",
                                "network_l2proxy": "true",
                                "network_phys_macvlan_mtu": "true",
                                "network_veth_router": "true",
                                "pidfd": "true",
                                "seccomp_allow_deny_syntax": "true",
                                "seccomp_notify": "true",
                                "seccomp_proxy_send_notify_fd": "true"
                        "os_name": "Ubuntu",
                        "os_version": "24.04",
                        "project": "default",
                        "server": "incus",
                        "server_clustered": false,
                        "server_event_mode": "full-mesh",
                        "server_name": "librem-mini",
                        "server_pid": 10515,
                        "server_version": "6.0.0",
                        "storage": "zfs",
                        "storage_version": "2.2.2-0ubuntu9.4",
                        "storage_supported_drivers": [
                                        "Name": "btrfs",
                                        "Version": "6.6.3",
                                        "Remote": false
                                        "Name": "dir",
                                        "Version": "1",
                                        "Remote": false
                                        "Name": "lvm",
                                        "Version": "2.03.16(2) (2022-05-18) / 1.02.185 (2022-05-18) / 4.48.0",
                                        "Remote": false
                                        "Name": "lvmcluster",
                                        "Remote": true
                                        "Name": "zfs",
                                        "Version": "2.2.2-0ubuntu9.4",
                                        "Remote": false
DEBUG  [2026-03-06T11:39:40+01:00] Connected to the websocket: ws://unix.socket/1.0/events?project=user-1000
DEBUG  [2026-03-06T11:39:40+01:00] Sending request to Incus                      etag= method=POST url="http://unix.socket/1.0/instances?project=user-1000"
Importing instance: 100% (39.20MB/s)Error: Post "http://unix.socket/1.0/instances?project=user-1000": EOF
Any hints how to hand over the containers correctly?
uname -a Linux librem-mini 6.8.0-101-generic #101-Ubuntu SMP PREEMPT_DYNAMIC Mon Feb  9 10:15:05 UTC 2026 x86_64 x86_64 x86_64 GNU/Linux
lxd --version 6.7
LXD has two backup formats, you’ll want to use v1 for something that Incus can import. There should be a flag in lxc export to control that.
Helped a lot…Did the trick…Adding --export-version 1 solved it…:clinking_beer_mugs:
