In lxd, how to find containers by searching for process containers
Similar to docker commands such as: docker ps -q | xargs docker inspect --format ‘{{.State.Pid}}, {{.Name}}’ | grep “PID”
Assuming I understood your question properly, ps faux
from the host should let you find which container has a given process in it:
$ ps faux | tail -n 23
root 3415 0.0 0.1 1125296 14436 ? Ss 02:02 0:05 [lxc monitor] /var/snap/lxd/common/lxd/containers smb
1065536 3482 0.0 0.0 99620 7552 ? Ss 02:02 0:03 \_ /sbin/init
1065536 3712 0.0 0.1 39476 9088 ? Ss 02:02 0:00 \_ /lib/systemd/systemd-journald
1065636 3744 0.0 0.0 16068 5520 ? Ss 02:02 0:00 \_ /lib/systemd/systemd-networkd
1065637 3889 0.0 0.1 25216 9756 ? Ss 02:02 0:00 \_ /lib/systemd/systemd-resolved
1065536 3978 0.0 0.0 9464 1604 ? Ss 02:02 0:00 \_ /usr/sbin/cron -f -P
1065640 3996 0.0 0.0 152768 3176 ? Ssl 02:02 0:00 \_ /usr/sbin/rsyslogd -n -iNONE
1065536 4655 0.0 0.1 86700 15352 ? Ss 02:03 0:00 \_ /usr/sbin/smbd --foreground --no-process-group
1065536 4666 0.0 0.1 84576 8372 ? S 02:03 0:00 \_ /usr/sbin/smbd --foreground --no-process-group
1065536 4667 0.0 0.0 84568 5724 ? S 02:03 0:00 \_ /usr/sbin/smbd --foreground --no-process-group
root 3802 0.0 0.1 1125296 14580 ? Ss 02:02 0:04 [lxc monitor] /var/snap/lxd/common/lxd/containers squid
1589824 4018 0.0 0.0 99580 7504 ? Ss 02:02 0:02 \_ /sbin/init
1589824 4197 0.0 0.1 31284 8912 ? Ss 02:02 0:00 \_ /lib/systemd/systemd-journald
1589924 4245 0.0 0.0 16068 5488 ? Ss 02:02 0:00 \_ /lib/systemd/systemd-networkd
1589925 4278 0.0 0.1 25480 9964 ? Ss 02:02 0:00 \_ /lib/systemd/systemd-resolved
1589824 4281 0.0 0.0 9464 1628 ? Ss 02:02 0:00 \_ /usr/sbin/cron -f -P
1589928 4285 0.0 0.0 152768 3108 ? Ssl 02:02 0:00 \_ /usr/sbin/rsyslogd -n -iNONE
1589824 4347 0.0 0.1 63968 11996 ? Ss 02:02 0:00 \_ /usr/sbin/squid --foreground -sYC
1589837 4353 0.0 0.6 110640 55732 ? Sl 02:02 0:07 \_ (squid-1) --kid squid-1 --foreground -sYC
1589837 4365 0.0 0.0 6060 1576 ? S 02:02 0:00 \_ (logfile-daemon) /var/log/squid/access.log
nut 154588 0.0 0.0 5464 2312 ? Ss 05:35 0:00 /lib/nut/upsd
sdeziel 684990 1.5 0.1 18624 9968 ? Ss 18:48 0:00 /lib/systemd/systemd --user
sdeziel 684991 0.0 0.0 103180 3468 ? S 18:48 0:00 \_ (sd-pam)
In the above, we see the smbd
daemon executes inside the container named smb
. This is identifiable by the parent process [lxc monitor] /var/snap/lxd/common/lxd/containers smb
HTH,
Simon
Yes your method is right, thanks. But I have more than 500 containers, I quickly find that container by this command。
grep -rn PID /sys/fs/cgroup/pids/*
That’s right, TIL Thanks!
$ grep -lwm1 4655 /sys/fs/cgroup/pids/lxc.payload.*/*/*/tasks | sed 's/.*lxc\.payload\.//; s/\/.*//'
smb
