kamzar1
(Dauerurlaub)
May 11, 2022, 9:48am
1
I remember, while ago, container had shown the right size corresponding with config limits.memory=
It had worked with Ubuntu free -m, with alpine /proc/meminfo.
Now to get back to that status, need to apply lxc config set a1 security.syscalls.intercept.sysinfo=true
to each container and restart them?
sysinfo=true should actually be default, as it was the state of things before lxd version upgrades and it also delivers true information within container, which again speaks for a default situation.
tomp
(Thomas Parrott)
May 11, 2022, 9:55am
2
No. Emulation of /proc/meminfo is provided by LXCFS (default enabled in the LXD snap package).
The security.syscalls.intercept.sysinfo is only needed if your application doesn’t rely on /proc/meminfo.
kamzar1
(Dauerurlaub)
May 11, 2022, 9:59am
3
lxd 5.1-4ae3604 23001 latest/stable canonical✓ -
somehow limits.memory=8GiB not working anymore.
Container showing the total server memory, despite:
image.os: ubuntu
image.release: focal
image.serial: “20210108_0856”
limits.memory: 8GiB
security.syscalls.intercept.sysinfo: “true”
after restart:
lxc exec c1 – free -h
total used free shared buff/cache available
Mem: 125Gi 556Mi 125Gi 85Mi 138Mi 125Gi
Swap: 0B 0B 0B
host free -h
Mem: 125Gi 62Gi 21Gi 770Mi 42Gi 61Gi
Swap: 29Gi 6.0Mi 29Gi
tomp
(Thomas Parrott)
May 11, 2022, 10:00am
4
If you didn’t need security.syscalls.intercept.sysinfo: “true” before to see the memory limits reflected in the container then you should disable it as you won’t need it.
Most likely LXCFS isn’t running, what does ps aux | grep lxcfs on the host show?
kamzar1
(Dauerurlaub)
May 11, 2022, 10:01am
5
tomp:
ps aux | grep lxcfs
root 3122644 0.0 0.0 520552 3572 ? Sl Apr28 1:38 lxcfs /var/snap/lxd/common/var/lib/lxcfs -p /var/snap/lxd/common/lxcfs.pid
tomp
(Thomas Parrott)
May 11, 2022, 10:02am
6
Have you tried restarting the container?
kamzar1
(Dauerurlaub)
May 11, 2022, 10:04am
7
I did, I aslo hard restarted lxd (snap restart lxd).
tomp
(Thomas Parrott)
8
Are you nesting containers?
tomp
(Thomas Parrott)
May 11, 2022, 10:07am
9
I’ve not been able to recreate using Focal LXD and container:
root@home02:~# snap install lxd --channel=latest/stable
lxd 5.1-1f6f485 from Canonical✓ installed
root@home02:~# lxd init --auto
root@home02:~# ps aux | grep lxcfs
root 2406 0.0 0.0 85660 1756 ? Sl 10:05 0:00 lxcfs /var/snap/lxd/common/var/lib/lxcfs -p /var/snap/lxd/common/lxcfs.pid
root 5066 0.0 0.0 6440 720 pts/0 S+ 10:05 0:00 grep --color=auto lxcfs
root@home02:~# lxc init images:ubuntu/focal c1
Creating c1
root@home02:~# lxc config set c1 limits.memory=2GiB
root@home02:~# lxc start c1
root@home02:~# lxc exec c1 -- free -m
Mem: 2048 29 2014 0 4 2018
Swap: 2048 0 2048
root@home02:~# free -m
Mem: 11777 366 9926 1 1484 11114
Swap: 4095 0 4095
kamzar1
(Dauerurlaub)
May 11, 2022, 10:08am
10
No, Host is Ubuntu focal 5.4.0-109-generic #123-Ubuntu
unprivileged containers on zfs pool (zfs-0.8.3-1ubuntu12.13.
tomp
(Thomas Parrott)
11
Does it occur on a freshly created container? It may be something inside the container is unmounting the proc files.
kamzar1
(Dauerurlaub)
May 11, 2022, 10:13am
12
You are right. In freshly created containers, mem is shown right:
lxc exec ub1 – free -h
Mem: 488Mi 40Mi 427Mi 0.0Ki 20Mi 448Mi
Swap: 0B 0B 0B
tomp
(Thomas Parrott)
13
So most likely something inside the container is unmounting/remounting /proc (possibly systemd)
kamzar1
(Dauerurlaub)
May 11, 2022, 10:15am
14
All existing (old containers) affected, no matter Ubuntu or alpine.
Only the newly fresh created behaved properly.
stgraber
(Stéphane Graber)
May 11, 2022, 5:21pm
15
I’ve moved this (now quite long) discussion to its own topic.
