Incremental backup of running containers
I am trying to set up incremental backups of containers.
In the latest lxc that I am using (v.3.13), it is possible to do:
lxc copy test remote:test --refresh
which supposedly should do incremental copy of my test container. Unfortunately, it does not seem to work when the container is running, as I get:
Error: Failed container creation: Cannot refresh a running container
I am trying the following workaround. I first copy the container locally:
lxc copy test test-copy
My storage pool is btrfs, so the local copy is shallow (fast).
Then I copy the resulting (not running) container to the remote:
lxc copy test-copy remote:test --refresh
My question: should this work?
I tried it on my machine (with the image ubuntu:18.04), and I get in the last step errors:
 - https://xxx.xx.xx.xxx:8443: Error transferring container data: exit status 1
 - https://10.xx.xx.x:8443: Error transferring container data: Unable to connect to: 10.xx.xx.x:8443
 - https://[fd42:****:****:****::*]:8443: Error transferring container data: Unable to connect to: [fd42:****:****:****::*]:8443
In syslog I have the following error message from btrfs:
host lxd.daemon[1649]: t=2019-05-29T22:56:06+0200 lvl=eror msg="Problem with btrfs send: ERROR: subvolum /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/test-copy/backup is not read-only\n"
This happens only when my container (test) has a snapshot (backup). When there are no snapshots, the refresh copy works fine. I have tried to reproduce this situation on a test lxd instance, which seem to use btrfs as well, but there it worked fine.
I am wondering if I experience some bug (with btrfs) or this is because I am not suppose to copy a volume used by a running container?
Looks like the problem is not only with running containers. When I stop the container before making the snapshot, the same error takes place:
lxc launch ubuntu:18.04 test
lxc stop test
lxc list # ensure test is STOPPED
lxc snapshot test backup
After about 10 seconds pause the same error message as above appears and the same error message is logged in syslog.
I can reproduce the same problem on 3 different hosts with ubuntu 18.04 (fresh install), btrfs storage pool, and snap version of lxd (v. 3.13).
Interestingly, copying of the original container works fine:
I have opened a ticket for this problem:
https://github.com/lxc/lxd/issues/5804#issue-450740533
